F-150 w/blackeye comeback build
#46
here's the bed.. You can see what half I have wire brushed and cleaned..
and here's a view from the side and the one cleaned wheel well
lastly here is some eye candy of the drag toy..
http://i1294.photobucket.com/albums/...ps747e7c30.jpg
http://i1294.photobucket.com/albums/...psf16baf17.jpg
http://i1294.photobucket.com/albums/...psd9dab981.jpg
#47
#48
here's pics of the tank so you can see what im seeing.. What exactly do I need to pull and unhook
http://i1294.photobucket.com/albums/...ps38fa1817.jpg
http://i1294.photobucket.com/albums/...psfb65d3f8.jpg
Lisle makes disconnect tools that will release the springs inside the fuel line that secure it to the tank. The link is to the complete cheapy set; if you don't want or need all of them I think the 5/16" is the correct size. (Or you can get the complete disconnect set or the other complete quick disconnect set if you'd rather.) To use it, close it around the nipple on the tank then slide the narrow end into the inside of the fitting on the fuel line. Push the fuel line back towards the tank and push the tool into the fitting until it's flush. The line should come right off then.
To reconnect the fuel line, push it back onto the fuel tank nipple. No tools necessary. And since you're this deep into it you might as well replace the fuel filter too, if it needs it. You'll have easy access to it with the bed off.
#49
on
ahh ok now I understand why you don't understand me your 96 is different from the trucks I have worked on to get the pump out. See the clips like on the lines I circled it in red in the pic below. Take a flatbladed screw driver underneath it like you are going to pry it off those are metal so you won't break em it should be fairly easy. Now you have to have a special tool to disconnect the lines of the fuel pump.
This link is similar tools your local autozone or such should have them fairly inexpensive my buddy got a similar set for $5 new: Lisle 37000 Air Conditioning Fuel Line Disconnect Tool Set GM Ford Chrysler | eBay
When you have that tool you push the tool over the metal part of the fuel line on the pump. Push it forward you may need to wiggle the lines a bit to get it to come off they are kinda stubborn.
For putting it back on it should just pop back on by pushing the line into the fuel pump itself line (Don't forget which line goes where take pictures and wrap it with colored tape so you know as I don't remember if on 96 they have certain sizes to fit on.) Other then that great work going on sorry for the confusion earlier. Also for the little white breather on top in the middle of the tank I would advise you to take the whole thing out a it does break easily trying to take the hose off the breather.
Trav
Trav
#51
#53
this is fairly simple, what size star bit is needed for the seat belts?
http://i1294.photobucket.com/albums/...ps19778650.jpg
#55
gracias, im gonna go ahead and replace the fuel pump while I've got the bed off, but I was shoppin around at autozone and a fuel pump wll run me about 150$ and spectra offers this Spectra Premium/Fuel Pump and Tank Assembly (F1G1FA) | 1996 Ford F150 1/2 ton P/U 4WD 8 Cylinders N 5.0L EFI | AutoZone.com_
its a new tank and everything already installed, so it would basically just be unhooking the old and hooking up the new right? A new gas tank wouldn't hurt I mean I would probably replace it anyway.. Plus ive got 40$ in autozone bucks saved up so it'll be 40$ off that price
