horn quit working?
Old May 19, 2013 | 09:40 PM
FordYoungGun35's Avatar
FordYoungGun35
horn quit working?
idk why but my horn just quit working there hooked up fine followed the wires they look okay.. could it be a fuse? i bought an air horn to hook up anyways how could i wire that so it can be used with the buttons on my steering wheel?
Old May 20, 2013 | 05:55 AM
CLR f-150's Avatar
CLR f-150
First is your rad supoort rotted cause if it is could be a bad ground. The wire going to your horn you would just hook it up to you air horn relay there should be instructions with them to tell you , I did that on my truck once the horn quit worked great
Old May 20, 2013 | 09:39 AM
FordYoungGun35
Other than the typical surface rust on the frame there isn't rust anywhere
Old May 20, 2013 | 09:49 AM
OldGrayFord's Avatar
OldGrayFord
It could be a fuse. My 89 shares a fuse with the cig lighter socket. I once had a penny get in the socket and blow the fuse.
Old May 20, 2013 | 06:53 PM
garthneddy's Avatar
garthneddy
The horn isn't grounded throught the rad support. Run a jumper wire from the steering shaft to the frame. If your horn works then the problem is a bad ground in the rag joint.
Old May 21, 2013 | 06:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
i don't remember if the 96 column has a clock spring or not, but the first sign of a bad clock spring assembly is the horn stops working.
mark996
Jun 26, 2016 07:10 PM
garydmundy
Dec 18, 2012 03:14 PM
Thurisaz
Feb 6, 2011 07:40 AM
maldbwmjr
Jan 13, 2008 12:29 PM
crussel4
1978 - 1996 Big Bronco
Sep 4, 2003 11:37 PM
