pitman arm
Old May 19, 2013 | 12:18 AM
e6ug's Avatar
e6ug
pitman arm
i am in the process of converting my 69 f100 to power steering. i am using a ps pump,gear, column, driver side fe engine perch from a 69 f250.
my next project will be to add front disc brakes.
i understand there will be differences in king pin diameters.
my question is, will i need a different pitman arm if i am using a 73-79 f100/f150 donor truck?
thanks for any help. sorry if this has been answered before, i have been doing some reading, and getting some conflicting information.
Old May 19, 2013 | 10:15 AM
HIO Silver's Avatar
HIO Silver
You really need to read through all of the following articles. The first article will answer your question:
Steering/Suspension Component Variations - FORDification.com
Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
Comparing I-beams and Spindles - FORDification.com
Old May 20, 2013 | 12:17 PM
e6ug's Avatar
e6ug
Thank you for the links.
BrentF100-68
13
Dec 1, 2017 01:52 PM
rwrogers
Mar 29, 2014 10:36 PM
gofrogs69
Jan 2, 2013 01:52 PM
FIFTFODOKUSTOM
Sep 26, 2005 01:34 PM
67heinz57
May 31, 2003 06:51 PM
