Audio Install
Old May 18, 2013 | 12:32 AM
rottenstock's Avatar
rottenstock
Audio Install
So my truck never came with a radio...I only say that because I have no antenna hole where most others do.
Quite honestly, I'm not sure if I actually want to drill a hole for antenna.
What I thought about doing was putting a small amp under my seat and hooking it to the door speakers and just running a "Y-cable" from the amp input to my mp3 player.
Has anyone done this or a setup like this? Ideally I'd put the amp behind the seat but I have an in cab gas tank and I don't really want to drill into it.
Old May 18, 2013 | 04:04 AM
co425's Avatar
co425
I have the same issue. I am considering a radio as well. My plan is to put a powered antenna under the dash versus drilling the hole for the antenna.
Old May 18, 2013 | 04:16 AM
Canus's Avatar
Canus
Check out this thread on another site. Should answer your question. HOW TO: ipod into hotrod without a radio - THE H.A.M.B.
Old May 18, 2013 | 09:36 AM
brian1080's Avatar
brian1080
in my 89, I ran a powered sub and a small amp pushing some door speakers behind the seat. From there I ran a y up to the dash so I could plug my iphone straight into the amp. Worked perfect, was hidden and gave me hands free phone. It's simple to do, so go for it.
Old May 18, 2013 | 10:03 AM
fmc400's Avatar
fmc400
MSEE
When you say "y-cable", are you talking about a stereo cable that splits a 3.5-mm stereo plug into left and right channels (RCA phono plugs)? If so, that will work.
In my opinion there is not enough worthwhile stuff on the radio these days to justify drilling a hole in original sheetmetal
Old May 18, 2013 | 10:47 AM
brian1080's Avatar
brian1080
yeah, that's what I believe he meant, and I know it's what I was talking about.
Exactly on the radio being worthless. I never listen to the radio anymore thanks to 1 song - 5 commercials. I also don't use CD's anymore, so a full head unit is kinda of pointless. With a dvd screen, it makes it more useful but still for the money, it's a toss up. I'm probably going to go back to the y cable route in my Scab, and just have a loud system run from my phone.
Old May 18, 2013 | 10:51 AM
GM4WALLS's Avatar
GM4WALLS
Kicker and a couple of other brands build small external amplifiers that directly use eother a 3.5mm input jack or USB input as the source. Power, ground and speaker leads are all you need to run, so installation is simple. Check Crutchfield for companies building amplifiers equipped with this onboard processing and you can buy them at a discount from Woofers Ect.com, they have excellent priecing and terrific customer service... I have spent thousands with them.
Old May 18, 2013 | 01:29 PM
rottenstock
I found the following amp that has a 3.5mm jack on it. I might look into it....especially for the price...but then again, you get what you pay for.
At this point, $20 for music sounds pretty amazing!
Pyle - PLMPA35 - 2 Channel 300 Watt Mini Amplifier w/3.5mm Input
Old May 18, 2013 | 01:41 PM
GM4WALLS's Avatar
GM4WALLS
Pyle is extremely low end, a high product failure rate is what they are know for, as well as bloated specs. Personally, I would find a better product and do it right the first time.
Old May 18, 2013 | 01:44 PM
rottenstock
Well im doing my research that's for sure. That was just the first one I've come across. So they do exist.
I don't know if it would be better to get a USB one or a 3.5mm connection for the mp3 player.
The USB would be nice because of the charging aspect.
Old May 18, 2013 | 01:58 PM
GM4WALLS's Avatar
GM4WALLS
USB will be slightly cleaner and offee charging.
Old May 18, 2013 | 02:08 PM
rottenstock
Yeah, I know USB is cleaner and offers charging. I'm not having much lucking finding a good amp though. The only one's i've found so far are "Pyle" and "Kinter".
I've done searches using "2 channel amp with usb input"; "2 channel amp with aux input"; "2 channel car amp with usb input", etc. Still "pyle" and "kinter" come up.
I have seen ones with iPod controls, but I don't have an iPod. I've got an android phone.
Old May 18, 2013 | 02:19 PM
GM4WALLS's Avatar
GM4WALLS
Kicker makes one... I installed one for a friend. You can call Woofers ect.com customer service and they can lead you to specific products.
Old May 18, 2013 | 02:48 PM
rottenstock
Are you refering to this one:
PXi50.2 | KICKER
Old May 18, 2013 | 02:58 PM
GM4WALLS's Avatar
GM4WALLS
PXi50.2 | KICKER
Yes, I am not a Kicker fan but that is a really noce little product.
