Sponsored by: Real Truck
F550 Driveshaft
Old May 17, 2013 | 10:25 PM
RangerTuff05's Avatar
RangerTuff05
F550 Driveshaft
I recently bought a 2000 F550 crew cab and it has a Vanair Split Shaft compressor on it. Its an odd set up. There is a driveshaft coming out of the 4R100 trans(2 wheel drive) that goes to the compressor and then a shaft comming out of that going to the rearend. I think the bearings are starting to go in the compresser unit so I'm trying to get ideas on what a good donor vehical would be for a new shaft. There is an 04 crew cab long bed 2 wheel drive and a 00 E350 Bus being parted out in the area. If the wheel base is the same, I believe mine is 176, would the drive shafts work of do you have any other suggestions? I'm not that interested in spending 1000 dollars on a driveshaft.
Old May 17, 2013 | 11:11 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Can you post some photos? The compressor is driven by the output shaft vs a PTO drive?
Old May 19, 2013 | 05:24 PM
RangerTuff05
Im not sure how to upload pictures. Do you have any hints? I took pictures today with the wifes phone.
Old May 19, 2013 | 05:34 PM
RangerTuff05
So I just made an album. I'm assuming that you are a little better at navigating the site then I am so I'm sure you will find it. As for what drives it I'm not exactly sure. It has a pto attached to the unit as well. Ive never seen anything like it. To engage the compressor you first shift the transmission into drive then back to park hit the pto and the parking brake then shift it back into drive. It makes no sense but thats what the manufactur instructions say to do.
Old May 20, 2013 | 08:09 PM
RangerTuff05
Any Suggestions?
weldertant
Jun 13, 2019 04:29 PM
paddler
Dec 9, 2012 10:16 PM
loganmd37
Jul 4, 2012 01:52 PM
The_SnowMan710
Aug 18, 2008 11:10 PM
War_is_my_Shepherd
Apr 22, 2005 12:25 AM
