Jumped Time Symptoms
Old May 16, 2013 | 12:10 PM
UZI-SUICIDE's Avatar
UZI-SUICIDE
84 F-250 - 351CI/5.8L - 4 Spd - Motocraft 2150 carb - Duraspark II
Yeah I am back.. A new thread for the same problem
Gave up on messing with the distributor.. I am thinking this truck has jumped time..
Can anyone give me symptoms or tests to diagnose whether an engine has jumped time?
Old May 16, 2013 | 03:45 PM
CountryBumkin's Avatar
CountryBumkin
Maybe start by rotating engine around until the timing pointer is at 10 degrees BTDC (or whatever you set your timing to) and see if the rotor is pointing right at the number the one plug wire terminal. Give or take a few degrees. If your 10 or more degrees off something is wrong.
Old May 16, 2013 | 08:28 PM
ctubutis's Avatar
ctubutis
I would put #1 at TDC of the compression stroke, the pointer on the balancer should point to 0.
The balancers are made of two pieces with rubber holding them together, that rubber deteriorates and the two pieces slip so maybe that's your problem, instead.
Old May 17, 2013 | 04:40 AM
CountryBumkin
That's a good idea to see if the damper has failed/slipped, but keep in mind that if the timing chain jumped a tooth (or is stretched considerably), the crankshaft damper will still point to 0 with piston at TDC - it's the cam (valve events and distributor timing) that are out of sync in that scenario.
Old May 17, 2013 | 05:50 AM
Franklin2's Avatar
Franklin2
If the timing chain has jumped, it's been my experience it will not run, and when cranking it cranks strangely. By that I mean it doesn't have a steady rhythm. It will speed up and slow down in a strange pattern as it's cranking.
dionysius
18
Jun 12, 2017 06:45 PM
LilBear'65
16
Mar 12, 2015 10:16 PM
my69ford
Jun 1, 2006 12:10 PM
GSchretter
Oct 6, 2004 02:06 PM
CO_87Bronco
Jun 7, 2003 11:24 AM
