Speedometer issue
Old May 15, 2013 | 10:23 AM
brown1911's Avatar
brown1911
Speedometer issue
Throwing this out there hoping for some useful info.
1999 Ford Ranger 4.0 auto 4X4
Speedometer works fine during the day.
During night time driving, after about 10 min with headlights on speedometer will stop working.
Any thoughts?
Thanks
Old May 15, 2013 | 10:58 PM
pawpaw's Avatar
pawpaw
If you use the dash dimmer to turn the dash lights Off, does the speed-o still act out????
Old May 16, 2013 | 07:19 AM
tomw's Avatar
tomw
I would check the headlight switch for getting hot, check grounds, and check the connectors to the back of the cluster. The headlights use electricity, and also turn on the cluster lights. If there was a bad ground or poor connection to the cluster, it might make the speedometer become the pathway to ground to run the lights... or the radio .. or the blower motor .. or wipers .. Once connections are un-made for any reason, weird stuff can happen.
tom
Old May 16, 2013 | 06:33 PM
KF4EYR's Avatar
KF4EYR
what tomw said,, and check your grounds to the cab, i had a lot of problems with my 99 ranger because of that also your altenator could be getting weak or going bad.
Old May 16, 2013 | 08:12 PM
brown1911's Avatar
brown1911
Thanks for the replies.
1st when turning the dimmer down it takes longer to kill speedometer, but it does.
2nd new alternator.
3rd have not got into dash yet to check stuff. which grounds do you think would affect this issue.
Thanks for responses
Old May 16, 2013 | 08:25 PM
mfp4073's Avatar
mfp4073
2nd new alternator.
was this happening before the alternator was installed?
Old May 16, 2013 | 11:34 PM
KF4EYR's Avatar
KF4EYR
mine was the body to the motor ground and the battery to the fender ground,
Old May 17, 2013 | 06:37 PM
michigan66's Avatar
michigan66
Did this problem exist before or after the alternator was replaced?
Old May 25, 2013 | 10:22 PM
brown1911's Avatar
brown1911
Problem solved. Found wire under dash the one that goes to the parking brake for the light had grounded out. It had been cut into in the past. Whoever patched wire did a crappy tape job. Respliced and heat shrink. Everything is well now. Oh and replaced shot fuse. Thanks for responses.
Old May 25, 2013 | 11:25 PM
pawpaw's Avatar
pawpaw
OK, good find, fix, feedback & to hear all is well & your on the road again without the speed-o acting out. First I've heard of this type of problem messing with the speed-o.
ScareCrowMantis
17
May 20, 2017 12:36 PM
mysherona
Sep 17, 2015 08:30 PM
Dynam1te
Electrical Systems/Wiring
May 2, 2013 01:20 AM
kennyrandolph
Sep 1, 2009 09:23 PM
ddrumman2004
1997 - 2003 F150
Jan 14, 2009 08:25 AM
