rear gear change
Old Jun 7, 2003 | 05:42 PM
eharman's Avatar
eharman
rear gear change
Is it possible to change the rear gearing of a 2000 F150 from
3.55 LS to 3.73 LS?. I was told that you could not because of the
computer.
Old Jun 7, 2003 | 08:51 PM
steve83's Avatar
steve83
rear gear change
Yes, you can change it to whatever you like, as long as you reprogram the computer for it. If that ratio was offered, a good OBD-II scantool should be able to reset your computer. Many parts stores will do it free, but check around. You may have to go to the dealer, so talk to them about it.
