NEW CLUTCH
Old May 14, 2013 | 04:15 PM
SIXTFOR's Avatar
SIXTFOR
NEW CLUTCH
Can anyone please reccomend a new clutch????
64 ford f100
292 all stock except headers
Old May 14, 2013 | 08:12 PM
vntgtrk's Avatar
vntgtrk
I've used Sachs clutch kits all my life, even when I was doing clutches professionally. They're as good as anything out there. The most important part when it comes to clutch life is your left foot.
Many will say not to bother having your flywheel resurfaced. I say, *****, you're already there. Do it right. Any other wear parts, like your clutch fork, etc. well, take a good look. A clutch job is not an easy job. Do ya wanna tear it back apart? Didn't think so
Old May 14, 2013 | 09:31 PM
Macs1964F100's Avatar
Macs1964F100
Thank you for the input. I have the same truck and am going to need a clutch soon. Are the Sachs a diaphragm style? I am getting older and want the easier effort of diaphragm style clutch.
Old May 15, 2013 | 08:31 AM
tinman52's Avatar
tinman52
Welder User
I haven't had very good luck with aftermarket replacement clutches.....
So I save every old one I come across. There are still places that will rebuild them.
Old May 15, 2013 | 09:21 AM
vntgtrk's Avatar
vntgtrk
diaphragm clutch diagram - Yahoo! Search Results
This is pretty close to what the Sachs clutch kit I got for my '59 looks like (second one from the left, bottom row).
Old May 15, 2013 | 09:55 AM
SIXTFOR's Avatar
SIXTFOR
The last clutch that was put in i can tell you that it was not done right at all because reverse was never smooth and had a burning smell every damn time cause u had to ride it to get it to work.. i called the shop on it and they stated that i needed to wok it in as it is new... here it is 13 years last and REV, still not worth a SH#T.. i only drive it about 1000 mile a year.
so when you say that after market are not that good.. well the one i had put in is crap.. thats why i need recomendations on good ones that will lasst.
Old May 15, 2013 | 11:01 AM
Macs1964F100
How is your pedal effort? Same as stock or less?
Old May 15, 2013 | 11:30 AM
SIXTFOR's Avatar
SIXTFOR
my pedal is stock.
so i looked at the site for sachs and its all in euros and there is no 64 for truck selection.
Old May 15, 2013 | 12:21 PM
vntgtrk's Avatar
vntgtrk
I'm still building the truck, so I have no idea. Won't for about a year
Old May 15, 2013 | 12:28 PM
vntgtrk's Avatar
vntgtrk
Originally Posted by SIXTFOR
my pedal is stock.
Ford Truck F250 F350 Ford F 100 Pickup K0162 01 New Clutch Kit | eBay
Not sure of your clutch size. Do you have a 10" or an 11"? Looks like if you have a Y block and 10" you may have to go to a different brand.
Old May 15, 2013 | 02:16 PM
SIXTFOR's Avatar
SIXTFOR
YAH I STILL HAVE THE ORIGINAL 292 IN IT AND STILL HAS AN OIL BATH!
Old May 15, 2013 | 03:42 PM
charliemccraney's Avatar
charliemccraney
Check your cab mounts, particularly the driver side. If it is trashed, your clutch will never work smoothly.
Since you only drive it 1000 miles a year, I assume that means you can have it apart for a while. If this is correct, tear it down and see if you can find what you need at a local parts store. If you can't, try a place that specializes in clutches. I found a stock replacement at Carolina Clutch when I was looking 5 years ago or so.
And if all else fails, you can look into having yours rebuilt.
Old May 15, 2013 | 04:37 PM
SIXTFOR's Avatar
SIXTFOR
YAH !
the cab mounts are 100% trashed and gone. the cab was rewelded before i got it.
Old May 15, 2013 | 05:53 PM
vntgtrk's Avatar
vntgtrk
Meaning it's already been repaired?
Old May 16, 2013 | 06:04 AM
old broke prospector's Avatar
The last clutch kit I put into a 66 352 has the "new" diaphram release. My first thought was how too soft it feels, like a worn out pressure plate. I think an old term for the feel is "mushy". I prefer the feel of the old springs. I hope it out lasts the old spring style. I will not bet either way on it.
