ok so first all you guys are awesome have gotten a lot of help but this is still troubling me 78 f100 current tank is leaking it has the top vent in tank that goes to the charcoal filter next to alternator problem is the filter is gone and line is plugged already has vented gas cap on to make up for plugged line .
so do i get new tank with out hole? or get one with and new filter and cap?
ps runs like a champ atm lil rich but haven't gotten into carb much yet
ok so got new tank no Evap/Em fuel vapor valve installed easy.
BUT it started building pressure in the tank creating fuel spray out of cap when opened on occasion but mostly just pressure.
picked up a new stant 10574 fuel cap now i am getting fuel drip out of cap inspected it rubber seal is shot after a month.
bad cap? yea probably. but why am i pushing fuel out and were there diffrent size filler necks?
ps no issues whal driving
only had problems starting when i used gas from a station that just found water in there tanks and had them "flushed" glad i didnt fill up
ok so in that case a unleaded cap would not fit a leaded neck so its not that my neck is to big its just fail cap is there a more reliable brand something that's made last year or 2 maybe or a way to try and save rubber cause pepboys only had 2 in warehouse stock so my return will get me same problem i believe
