Help 390 ignition problems
Old Jun 7, 2003 | 05:20 PM
jeebs2k22's Avatar
jeebs2k22
Unhappy Help 390 ignition problems
Help
My father-in-law has a 1964 1 ton. He bought the truck from someone who switched out the original engine for a 390 w/ electronic ignition. He has a problem with it dying. It will start ok, but only run for a bout a mile or two, then it dies. If you let it sit for about five min. it will then start back up. We changed out the ignition control module and it kept doing it. We have checked to see if it is getting spark, and it is. It is also getting plenty of fuel. We are kind of at a loss for what to do next. Anyone have any suggestions? Any would be appreciated.
Thanks
Old Jun 8, 2003 | 05:13 PM
gtex's Avatar
gtex
Have you tried a new/different coil?
Old Jun 8, 2003 | 06:00 PM
nevrenufhp's Avatar
nevrenufhp
My nephew's truck is doing the same thing, and we tried a couple new coils. My other guess is the pickup assy, or the resistor wire(ballast). Someone else looked at it and said the MSD is the culprit....so, I gotta start looking at it this week and find out. That or put a diesel in it .
Old Jun 8, 2003 | 06:42 PM
jeebs2k22's Avatar
jeebs2k22
that is what we are going to try today. thanks
Old Jun 9, 2003 | 11:27 AM
chissler's Avatar
chissler
Sounds like a pickup coil, let us know
Old Jun 9, 2003 | 04:05 PM
jeebs2k22's Avatar
jeebs2k22
we are trying the pick-up coil today. i hope it works. Thanks for the suggestions.
Old Jun 9, 2003 | 05:01 PM
hotrodfeguy's Avatar
hotrodfeguy
I had this problem with my F-150 351 M I bought a rebuilt dist and had no further problems.Now it was prolly the pick up or reluctor wheel either case i just bought a rebuilt distributor was only 42 bucks and just had to slap the thing in.
Old Jun 10, 2003 | 04:24 PM
jeebs2k22's Avatar
jeebs2k22
well we have tried the coil, and a new pickup. Nothing. anyone wanna buy a truck?? we just don't know what else to do.
Old Jun 10, 2003 | 04:34 PM
gtex's Avatar
gtex
Plan B
1. Purchase some starter fluid/spray.
2. Start the engine and let it idle until it starts to die, the spray in fluid.
Maybe your fuel pump is giving up after running a bit.
It's a cheap and easy diagnostic to determine if your problem is ignition or fuel related.
Old Jun 10, 2003 | 04:36 PM
jeebs2k22's Avatar
jeebs2k22
ok I will definitley try that. we are at our wits end.
Old Jun 10, 2003 | 08:44 PM
jeebs2k22's Avatar
jeebs2k22
Hey everybody, Thanks for all of your help, we changed out the fuel filters and they were totally nasty. Put new ones on it and it runs to quote my father-in-law "like a gut-shot panther" We appreciate all of the suggestions.
Old Jun 15, 2003 | 05:59 PM
kevin71100's Avatar
kevin71100
Gut shot panther!! That's a good one, mind if I steal it?
The same thing was happening to me and it turned out to be the fuel pump was failing with a big hill between me and my house but the old girl made it up and to the house.
Old Jun 15, 2003 | 10:36 PM
gtex's Avatar
gtex
Thanks for the follow up and the cool analogy, or metaphor or similie...I can't ever get them straight.
You may have helped me solve a dying issue on another truck..
john6teen33
16
Apr 22, 2017 11:40 AM
john6teen33
Apr 21, 2017 02:46 PM
lalberts
Feb 20, 2017 11:34 AM
nelsonw
Aug 29, 2016 01:49 PM
Meagan Izquierdo
Feb 25, 2016 10:43 AM
