rear diff
Old May 12, 2013 | 05:03 PM
big todd's Avatar
big todd
rear diff
my 52 f2 has stock 4.88 gears I would like to swap rear ends what year if any will be the easiest swap I have heard 89 econoline will bolt in any help would be appreciated ,,wondering in new mexico
Old May 12, 2013 | 05:08 PM
irondragon79's Avatar
irondragon79
Um as far as I know, an econoline would be far from a bolt in. The closest thing to a bolt on is a Dana 60 axle out of a 1972 or earlier f-250
Old May 12, 2013 | 05:18 PM
DR Smith's Avatar
DR Smith
Try the search feature.There have been many post on rear swaps.
Old May 12, 2013 | 05:32 PM
big todd's Avatar
big todd
thank you guys much appreciated
Old May 12, 2013 | 06:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum! Where in NM are you?
Old May 13, 2013 | 05:26 PM
big todd's Avatar
big todd
thanks, I am In albuquerque nm
I am still leaning how to navigate this site the people here are very helpful
ad I need all the help i can get
Old May 13, 2013 | 05:57 PM
ben73058's Avatar
ben73058
Hey Todd,
Welcome aboard! Your engine sure looks nice - How far along are you?
Ben in Austin
1950 F1
Old May 13, 2013 | 11:01 PM
big todd's Avatar
big todd
thanks I am actually almost finished if these trucks can ever be finished
for some reason my pics wont download to the site
must be the format I am not to hot on the computer
Old May 14, 2013 | 06:16 AM
ke6jcf's Avatar
ke6jcf
8.8
I put a 2002 Explorer 8.8 in mine. Very little welding, width is pretty much the same. You have to roll over the spring perches and add some shock mounts. Very easy welding. Bolt it all together if you can't weld it yourself and tow it to a welder, they shouldn't charge you much. The rear ends are cheap and you can get posi and disc's on your rig for next to nothing. Good luck and welcome!
-Doug
Old May 14, 2013 | 06:36 AM
ben73058's Avatar
ben73058
Hey Todd,
Here is the article from the Tips & Tricks section up at the top of the Forum. It holds most of the collective wisdom of what fits & what year salvage vehicle to look for. Like Doug above we used a 2001 Explorer 8.8 for our rear end. It was $125 from a salvage place - It didn't look like much but it cleaned up well & works fine. It came with 3.73 gears, disc brakes, & locking diff. We did have to use 1 inch spacers to get the wheels right in the fender wells but it was really pretty straight forward.
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
Ben in Austin
1950 F1 (351W/AOD)
Old May 14, 2013 | 08:22 AM
aussiecowboy's Avatar
aussiecowboy
That won't help if he wants to keep the 8 stud wheels. I used a 59 Dana 60, pretty much bolt in and a wide range of ratios available. The tailshaft will need to be shortened slightly.
Old May 17, 2013 | 10:29 PM
big todd's Avatar
big todd
Smile
like the aussie said I want to keep the 8 lug wheels
the stocker the better
thanks for the posts
Old May 17, 2013 | 10:31 PM
big todd's Avatar
big todd
looks like you are in abq also where are the fat fender friends hanging out?
Old May 17, 2013 | 11:54 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by big todd
for some reason my pics wont download to the site. must be the format I am not to hot on the computer
Welcome to FTE!
The pics have to be somewhere on the Internet first. Try this...
Go to Photobucket.com and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Old May 18, 2013 | 08:18 AM
big todd's Avatar
big todd
Originally Posted by Jolly Roger Joe
Welcome to FTE!
Hope that helps.
thanks I had the sizes wrong
