Fan shroud
Old May 11, 2013 | 07:29 PM
Michael Hoskins's Avatar
Michael Hoskins
Fan shroud
Does anyone have an idea of where I could get a fairly cheap fan shroud for a 79 f-250 with a 460? It has the desert cooler radiator, and I wanted to know if there was a website or someplace online I could get one for less then LMC. LMC lists a new one for about 250$. Your help is appreciated!!
Old May 11, 2013 | 08:13 PM
gmarcisz's Avatar
gmarcisz
I have one i took off my radiator when i did my rebuild. It has a crack in it but it would be easily fixed. I thought about putting it back on my truck but I could totally sell it to you a lot less than that if you'd like it? let me know! Gregmarcisz@gmail.com
Old May 12, 2013 | 10:03 AM
V10man's Avatar
V10man
Found 3 out here in AZ. $35-$45.
Old May 12, 2013 | 10:07 AM
Michael Hoskins
Are they on cragslist?
Old May 12, 2013 | 05:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D3TZ-8146-D .. 460 Fan Shroud-Use with Super Cooling Radiator only / Marked on upper left (drivers) side corner: D4TA-CA or DA / Reproduced
Applications: 1973/79 F100/350 / Available from Carpenter @ $120.00 (price from 2011 paper catalog) using this Ford part number, illustrated with dimensions.
1973/79 F100/350 460: Super Cooling Radiator standard equipment except 1973/74 F100/250's with standard cooling radiator.
Old May 13, 2013 | 03:30 PM
V10man's Avatar
V10man
I found them using aara.com
straightsix4x4
16
Jul 29, 2008 05:44 AM
sturzinator
Mar 27, 2007 04:31 PM
rad5c
Aug 7, 2005 10:53 PM
scootin
1978 - 1996 Big Bronco
May 4, 2003 03:13 PM
proeliator
Mar 19, 2003 03:29 PM
