torque convert seal
Old May 11, 2013 | 04:31 PM
pethjacob's Avatar
pethjacob
torque convert seal
Hi I have a 1995 f-350 with a 460 with 142000 miles 4 in lift what causes the torque converter seal to allow the tranny to **** tranny fluid out? Could that be the problem if the tranny is just pissing fluid? im not sure if it was but everyone I talked to said its the most common reason. how could I prevent it too?
Old May 11, 2013 | 04:41 PM
JWC 3's Avatar
JWC 3
If leaking from the bell housing , convertor seal , pump gasket , or cracked housing . Seal is most common . Over heating or excessive case pressure , if not wear , are the most common causes .
Old May 11, 2013 | 04:46 PM
pethjacob's Avatar
pethjacob
its coming out by the bell housing there is a circle that doesn't have a cap on and it was pissing out of that
Old May 11, 2013 | 04:55 PM
JWC 3's Avatar
JWC 3
If leaking from bellhousing , mixer needs to come out . Might neen some help if not handy with a wrench . Good luck ! Hope it is just the front seal .
Old May 11, 2013 | 05:01 PM
pethjacob's Avatar
pethjacob
Do you think I should also upgrade my tranny cooler? or if I replace the seal it should be fine
Old May 11, 2013 | 06:05 PM
JWC 3's Avatar
JWC 3
I personally like to upgrade all my tranny coolers That is just my opinion though .
B2RonNM
Bronco II
Jun 22, 2012 09:50 AM
Scout
May 26, 2012 05:49 AM
MrRogers
Nov 6, 2007 09:38 PM
my72ford
Aerostar
Apr 30, 2006 07:29 AM
