E40D + intercooler q's
Old May 11, 2013 | 02:53 AM
kc0stp's Avatar
kc0stp
Ill start with the "My E4OD is acting up" question, so when I first got this truck it would be hunting for a gear around 35mph, replaced the tach sensor since below 1500rpm I had no tach. Tach now works correctly but now its hunting for a gear around 40-45mph, normally if I lock out OD itll behave normally but might still get it hunting once in a while, every other speed it works flawlessly and with recent tranny cooler and temp gauge install its staying nice and cool (think I might have hit 200 once, otherwise 180ish). Easy fix or time to start saving for a bullet proofed E4OD?
Now for the intercooler question, planning on putting an air/water intercooler on here shortly (local company and with radiator + a/c condenser + tranny cooler space behind grill is at a premium) but Ill be honest and admit I have no idea how to clock the 093 turbo and get the factory intake snail off so I can plumb the intercooler lines (pics appreciated ) since all Ive ever done turbo wise is stock replacements when a school bus shells a turbo....like what happened today.
Old May 11, 2013 | 05:52 AM
turtlemann14's Avatar
turtlemann14
as for the turbo there should be 6 bolts on the back on the snail (inbetween the cold and hot side)
loosen them slightly, just enough to turn it.
Old May 11, 2013 | 10:54 AM
xcite's Avatar
xcite
Here is one example of an old setup I had.
Old May 11, 2013 | 10:56 AM
xcite's Avatar
xcite
If I where you I would go with a standard intercooler. If you position everything right it will fit depending on the cooler. That is what I had going on.
Old May 11, 2013 | 11:14 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
when was the last time the FIPL/TPS was changed/tested? it sounds like maybe you have a dead spot in it.
learn more;
https://www.ford-trucks.com/forums/1...ions-only.html
Old May 11, 2013 | 04:25 PM
kc0stp's Avatar
kc0stp
Thanks Ill give it a look see once I get the truck running again and hopefully I can get to most/all of them without to much trouble
learn more;
I set it at idle when I did the IP change otherwise I have no idea on condition/age (got the truck a year ago and its at 226k miles) so next time Im at the parts store Ill pick one up (they know me by name...)
As far as just using a standard air/air find me one that fits in front of the condenser, is 1" thick or less and doesn't require drilling holes in the radiator support (or removing ground clearance). Besides I like being different and the only real problems Ive ever heard of with air/water is to small of a radiator causing it to heat soak on long pulls (got biggest they offered that would fit and can add a second later if needed), while on the flip side an air/air heat soaks if your not going fast enough (like say offroading ) Besides fabbing up a mount for the intercooler and running the hoses all Im missing is some IAT gauges and that's just because I want to see what the delta is which will make it easier to tell if it heat soaks or not (would love to find one that compared 2 IATs and told you the diff)
Old May 12, 2013 | 10:57 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
I can help you dial in your FIPL if you need it. It can be a royal PITA! I want to intercool my 94 too, I have some interesting ideas. but right now I have no time, as I finally bought a house in Lakewood that is torn apart right now. It is on a third of an acre, do you need room to store any of those projects of yours? PM me.
wahlturfcare
Jun 20, 2016 03:09 PM
Russell N.
Feb 20, 2014 12:14 AM
ineedhelp92
Aug 14, 2013 05:45 PM
02GrayPowerStroke
Aug 5, 2010 09:27 AM
tuppence
Aug 31, 2009 08:21 PM
