1978 - 1996 Big Bronco
Toe in
Old May 10, 2013 | 08:43 PM
1973F100Kid's Avatar
1973F100Kid
Toe in
Hello Bronco family. Im a 20 year old proud owner of 1991 ford bronco eddie bauer. I started to have a issue when i decided to put some chrome 15x10 rims on the bronco. The front of the truck looks to have a toe in look. I took it to sears and they did an aligment and told me that everything was fine. They just adjusted the camber or caster a little bit. As soon as lift it still had that look. I doesnt pull to the side or anything. I was hoping some one had a solution to this cause i hate seing my truck like that. Im planning to lift it 2 inches by putting new 2 inch shocks and springs in the front. Would that fix the problem? I will appreciate the help .
Old May 11, 2013 | 02:47 AM
greystreak92's Avatar
greystreak92
If the alignment is within specs, there is no reason to change it. In fact, changing it would just be a detriment. In short, you can't "fix" something that isn't broken. Most F-series and E-series models of that era will demonstrate a slight toe-in appearance after backing up and return to "normal" when pulled forward again.
BTW, if caster was adjusted, so was camber and vice-versa. There is no way to adjust just one on a TTB axle.
Old May 11, 2013 | 04:19 PM
1973F100Kid
Ok sorry about the stupid question lol, but in other words its normal then right?
Old May 11, 2013 | 04:50 PM
NASSTY's Avatar
NASSTY
That will probably require another alignment afterwards.
Old May 11, 2013 | 09:10 PM
1973F100Kid
Yeah i kind of thought it would. Thanks guys.
jaazula
Jan 5, 2008 07:51 AM
Mush's 88
Mar 25, 2004 08:02 PM
littlebroncoII.d.l.
Bronco II
Nov 16, 2003 01:59 PM
sabre737
Aug 3, 2003 12:00 PM
windrider
Oct 28, 2000 10:48 PM
