diy d66 turbo
Old 05-08-2013, 09:00 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
diy d66 turbo
ok guys and gals if there is any. i am currently in the process of doing a diy d66 i aquired a 66mm turbo conversion kit from barder turbo services in pa i talked to the owner of the place for a good hour and half maybe more. i know it is expesive to but a turbo that is already set up but you can do it yourself for half the price. here are some pics of the set up the comp wheel is a billet wheel kinda like a larger version of the ww2 if you get my drift also has extended tips as well and very light compared to an normal d66 wheel also a little bit taller and also it comes with the 360 thrust bearing and everything needed to do a turbo rebuild
Old 05-08-2013, 09:33 PM
tshrager's Avatar
tshrager
tshrager is offline
Looks good Ronnie. Do you mind telling us the cost? Did you get just the wheel and the thrust bearing from them?
Old 05-08-2013, 09:51 PM
rodneywar's Avatar
rodneywar
i got the comp housing, backing plate, wheel and rebuild kit for 665
Old 05-08-2013, 09:54 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
So you keep the stock center section and exhaust housing?
Old 05-08-2013, 09:55 PM
rodneywar's Avatar
rodneywar
yup even the turbine as well
Old 05-08-2013, 09:57 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
That looks pretty good!
rodneywar's Avatar
rodneywar
also it isnt in the pics the other part of the thrust bearing is a two piece design the goes thru the 360 piece
Old 05-09-2013, 11:23 AM
fordpride's Avatar
fordpride
fordpride is offline
That's cool
Old 05-09-2013, 12:57 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
OP - any plans for that stock wheel? I need one!
Old 05-09-2013, 06:06 PM
rodneywar's Avatar
rodneywar
you can have it as i already have 3 of them just pm me the details
Old 05-10-2013, 08:03 AM
OldWoodsDiesel
awesome - PM sent!
Old 05-11-2013, 08:39 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
subscribed
Old 06-04-2013, 06:44 PM
nomad221's Avatar
nomad221
nomad221 is offline
Ronnie, hows the new wheel working out for you ? Is that a stock 1.0 housing in your pic ? How is the power gain ? Any change in EGT ? Does it spool faster than stock ?
New stage 1's in the near future and it's time to rebuild my turbo. I am very interested in Barders' kit.
Old 06-04-2013, 07:29 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Great find Rodney! Now I have plans for my spare turbo!
Old 06-04-2013, 08:21 PM
compaddict's Avatar
compaddict
compaddict is offline
Subscribed!
Quick Reply: diy d66 turbo
