Explorer 2008 factory wheel alignment specs
Old May 7, 2013 | 01:51 PM
davemassive's Avatar
davemassive
Can anyone here point me in the direction of the wheel alignment specs for a 2008 Explorer (US model). I've got one on import here in Dubai and tyre shop were not sure they had the data for my year.
Any help much appreciated
Thanks in advance
Dave
Old May 7, 2013 | 08:55 PM
FireMe's Avatar
FireMe
<table border="1" cellSpacing="0" cellPadding="3" width="100%"><colgroup><col align="left"><col align="center"><col align="center"><col align="center"></colgroup><thead><tr><th vAlign="top" align="center">Item</th><th vAlign="top" align="center">LH</th><th vAlign="top" align="center">RH</th><th vAlign="top" align="center">Total/ Split</th></tr></thead><tbody><tr><td vAlign="top" colSpan="4" align="left">Front </td></tr><tr><td vAlign="top">Camber</td><td vAlign="top">-0.5° ± 0.75°</td><td vAlign="top">-0.5° ± 0.75°</td><td vAlign="top">0° ± 0.75°</td></tr><tr><td vAlign="top">Caster (Explorer, Mountaineer)</td><td vAlign="top">4.4° ± 0.75°</td><td vAlign="top">4.6° ± 0.75°</td><td vAlign="top">-0.2° ± 0.75°</td></tr><tr><td vAlign="top">Caster (Sport Trac)</td><td vAlign="top">4.5° ± 0.75°</td><td vAlign="top">4.7° ± 0.75°</td><td vAlign="top">-0.2° ± 0.75°</td></tr><tr><td vAlign="top">Toe (positive value is toe-in, negative value is toe-out)</td><td vAlign="top">—</td><td vAlign="top">—</td><td vAlign="top">0.20° ± 0.20°</td></tr><tr><td vAlign="top" colSpan="4" align="left">Rear </td></tr><tr><td vAlign="top">Camber</td><td vAlign="top">-0.5° ± 0.75°</td><td vAlign="top">-0.5° ± 0.75°</td><td vAlign="top">0° ± 0.75°</td></tr><tr><td vAlign="top">Toe (positive value is toe-in, negative value is toe-out)</td><td vAlign="top">0.05° ± 0.20°</td><td vAlign="top">0.05° ± 0.20°</td><td vAlign="top">0.10° ± 0.20°</td></tr></tbody></table>
Old May 7, 2013 | 11:29 PM
davemassive
Thanks so much
Old May 15, 2013 | 08:22 AM
davemassive
Right just had the wheels aligned, does this look okay to everyone?
Old May 16, 2013 | 10:00 PM
FireMe's Avatar
FireMe
If it drives straight and doesn't drift or pull, I would call it good.
The left/right difference in SAI and included angle could indicate a bent knuckle, or could just be an anomoly. For your application, I wouldn't worry about it much anyway.
Old May 18, 2013 | 02:15 AM
davemassive
Should the SAI and included angle be the same for each side? or does someone have the specs for this? Thanks
dt444e
Feb 19, 2010 12:36 PM
Kraut
Sep 9, 2005 11:49 PM
