Air Conditioner
Tyson
Anyway, those are pretty easy to find as well as the NEW hang-on units made by several of the other companies.
I was in Classic Air in Tampa a while back and they sell both reconditioned OEM Mustang units and a slightly cheaper "look a like". Would'nt be hard at all to make any of those work. They are a LOT cheaper than the combo units that replace your current heater and have ducting running to both ends of the dash as well as a center outlet.
There aren't any "thru-dash" setups for our trucks, at least in kit form. For that you'd have to fab something up. But it can be done.
I don't know which engine you have, but bracket kits are available for most common Ford V-8's and 6 cyl's.
Here's some links that might help.
http://www.air-tique.com/
http://www.hotrodair.com/
http://www.vintageair.com/
http://www.oldairproducts.com/
http://www.ackits.com/
http://www.airpartsonline.com/
http://www.rainbowproductsonline.com/
< also try Classic Auto Air in Tampa, Fl. at 813-251-2356 or
813-251-4994. Talk to Errol Forsman, that's the guy that showed me around. They specialize in older A/C systems, and stock tons of new, NOS ( OEM & aftermarket a/c ) and
used parts for all makes.
And finally:
Old Air Products
3056 S E Loop 820
Ft. Worth, TX 76140
(817) 551-0602
Good luck!
