Gas mileage?
Old May 6, 2013 | 06:40 PM
1975MudRat's Avatar
1975MudRat
I would say 10 and if ya went with a 600cfm 4bbl you could get around 12 if you keep your foot out of the other 2 barrels
Old May 6, 2013 | 06:44 PM
devino246's Avatar
devino246
Originally Posted by Dave145
No way I'm selling this old truck. There's just something about this era truck that makes me have to have one in my garage.
I think the first two upgrades I'll make to it will be to give it dual exhaust and an upgraded msd ignition. I would upgrade the rear end to a lower gear ratio, but I like my immense pulling power.
Side thought: I know of a 1978 ford f250 4x4 that gets 9mpg and has a 400. Why would my 2wd truck get the same mileage as a full time 4x4?
MSD ignition would just be a waste of your money. A set of headers with dual exhaust would do you some good.
Old May 6, 2013 | 08:28 PM
tbear853's Avatar
tbear853
Some say 10, I think 12-13 is doable if all is in order, timing right, no vacuum leaks, plugs good, etc .... and the driver has a skilled right foot.
Old May 6, 2013 | 09:04 PM
jgavac's Avatar
jgavac
And also the position I'm being offered is a crash technician at a local research facility with a salaried position and about 40 hours a week...hopefully they will come through with a decent pay load to add to my existing pay check from my job at mc Donald's.
You mentioned you're in school. If it's high school (or are a minor), I do not believe you are allowed to work 40 hrs a week during the school year. Maximum that I can do with being at high school part time is 28.. If you're over 18 and school refers to college, then disregard that comment.
I agree with the others. Get yourself a beater. I was in the same boat as you with my 79. I wanted to DD it, but 7 mpg out of my 460 wasn't feasible. Depending on what kind of mileage you are looking for, you could probably find yourself a newer 2wd 1/2 ton, efi 300, and M5OD 5 speed. With a decent rear end you could probably get close to 20. Or you could go diesel. I did that, got myself a n/a 6.9 truck with a 5 speed and 3.55 gears. 18 mpg daily.
If you're looking for even better, find yourself a small car. Stay away from Geo's, rust problems. A good reliable small car made by Ford? Check out the late 80's early 90's festiva. My buddy has one, and I've driven it. Gutless as hell, but he gets 43 mpg.
-Jameson
Old May 6, 2013 | 10:03 PM
51fordf5's Avatar
51fordf5
Mileage? With that truck? Lol!
I daily drove it about 3 miles to and from school for like a month so it was the hardest driving you could do mpg wise and I pulled like 6 or 8 miles to the gallon. I never really took it on the highway, but I had it up to 80 mph once and that thing SCREAMS in the upper end with the gearing and no overdrive. I would definitely regear, go down to 3.73's or 3.50's. And that's a Dana 60 in there btw if you didn't know, so yeah she pulls nice. But yeah, if you regear and really make sure it's all tuned up, you could see 10 or 11 I'd say with the driving you described.
Old May 6, 2013 | 10:06 PM
Dave145's Avatar
Dave145
Im currently 18 and still a senior in high school, but I am graduating in a couple of weeks which is when I'll be starting my full time job.
Currently in regards to the truck, its had a recent tune up and has no vacuum leaks at all. Timing is correct and so is everything else on the truck too.
Old May 6, 2013 | 10:37 PM
bamaf150's Avatar
bamaf150
Originally Posted by GOVTMOD
I'm in the same boat. If I can't get my mileage up I'll have to sell mine.
I'm going to try to go to smaller jets. Then maybe a 4 bbl carb.
What are you averaging now?
Old May 7, 2013 | 07:18 AM
GOVTMOD's Avatar
GOVTMOD
I haven't done a accurate check lately but it's going to be about 8-10.
Old May 7, 2013 | 08:09 AM
ddowell1's Avatar
ddowell1
sounds like me and you have the same truck. except mine is 4wd. I have an Edelbrock 4bbl carb. Custom Machined intake, with true dual exhaust and mufflers. also my truck has a very small comp cam. If i can keep my foot out of it i get around 10-12 mpg. When i accelerate quickly and hold the engine at high rpm i get about 6
Old May 7, 2013 | 08:23 AM
Dave145's Avatar
Dave145
Hmm ok I'll have to stick to the back roads for now to make sure there's nowhere for me to stick my foot in it!
Old May 7, 2013 | 10:17 AM
Quadsport's Avatar
Quadsport
I have owned my 2wd 79 lariat 351m with auto and 2.73 gear for 30 years. Before I built the engine at 123000, it would 14 mpg.
Old May 7, 2013 | 10:58 AM
bamaf150's Avatar
bamaf150
Sure is nice looking truck, love those shortbed 4x4s. Dont know what you have for power but you might consider a 300 six if you have a V-8. I'm sure youre aware of that; you might could do the swap cheaply and still be able to keep the ride. Or buy the $400 beater 4 cyl mentioned earlier....
Old May 7, 2013 | 01:05 PM
  #28
GOVTMOD's Avatar
GOVTMOD
Sure is nice looking truck, love those shortbed 4x4s. Dont know what you have for power but you might consider a 300 six if you have a V-8. I'm sure youre aware of that; you might could do the swap cheaply and still be able to keep the ride. Or by the $400 beater 4 cyl mentioned earlier....
It's a 400 4spd. I don't have the resources to do a 'cheap' swap. I don't have the room for another vehicle either so I'm sink or swim.
A reliable, running beater will run about 500-1k around here which I could swing but I'd have to sell the truck soon after to make up for the $ and the space. I'll then have to wait until I get in a better situation and location before I picked up another dent.
Old May 7, 2013 | 04:59 PM
  #29
bamaf150's Avatar
bamaf150
I hear you, my situation isnt too different. What saves me is I dont have to do much driving, I get 12.5 mpg on the hwy if its tuned good, more like 9 around town.
Old May 7, 2013 | 06:04 PM
  #30
Blang525's Avatar
Blang525
On my first tank of gas I drove as gas-friendly as I possibly could with my 460 with a 4bbl carb. I was hoping for around 10-12 mpg. Boy was I wrong. I was barely at 8 mpg . I am now going to do a motor tune up. (spark plugs, carb tuning etc.)
