'37 Pickup project
Old Jun 27, 2013 | 02:49 PM
schoo's Avatar
schoo
Originally Posted by 91blaze
Seems the fuel regulator is screwy. Not sure if its just a bad part or something else is messed up.
do you a get cough, fart anything?
compression?
Old Jun 27, 2013 | 03:12 PM
91blaze's Avatar
91blaze
Nope, nothing. Compression is the next thing im checking if i cant get it started. Im thinking most likely problem is fuel delivery.
Old Jun 27, 2013 | 03:47 PM
91blaze's Avatar
91blaze
Now when i try to start it, i get a fairly loud "clunk" if i spray starting fluid in the carb. Not really a metallic sound, not sure how to explain it. Seems like its trying to start or something. I have a mechanic coming out sometime this week to look at it. Hopefully it wont be anything major.
Old Jun 27, 2013 | 09:06 PM
schoo's Avatar
schoo
I would not use to much starting fluid your dad may have put some oil in cylinders to stop rust has it been sitting long?
Old Jun 27, 2013 | 11:44 PM
91blaze's Avatar
91blaze
Prolly sat for about 8 months. I only put a little starting fluid to see if i was having fuel issues.
Old Jul 4, 2013 | 05:32 PM
91blaze's Avatar
91blaze
I need a little help. I am using a bypass type fuel regulator to go from the fuel pump to the carb. I think the reg may be backwards so i need someone to id which side is the input and which is the output. I took it apart and took pictures.
Old Jul 5, 2013 | 03:21 PM
91blaze's Avatar
91blaze
Worked on it a lot today. Fixed a no-spark issue but still unsure of the fuel problem (see previous post). Tried to start again and got a few pops like it was trying. Got a few puffs of smoke out of the right side somewhere so im having a friend come out and help. Hope everything goes well.
Old Jul 5, 2013 | 08:57 PM
christurney77's Avatar
christurney77
Keep working at it. You will get there soon. Wish I could help you with your issues, but I have limited knowledge myself...
Old Jul 6, 2013 | 12:56 AM
91blaze's Avatar
91blaze
I'm learning a lot from this project since it's my first one. I forgot to add grounds between the engine and frame, which is causing most of my problems. Tomorrow i will find out if the grounds were the only problems. The car show is next Saturday and this truck is going, running or not.
Old Jul 6, 2013 | 07:00 PM
91blaze's Avatar
91blaze
Grounds were definitely the problem. Installed a ground from starter to frame and now the starter turns about 5x faster. Tomorrow i will find out if it will start now. In thinking that the MSD box wasnt getting enough power while starting because of this.
Old Jul 8, 2013 | 01:06 PM
91blaze's Avatar
91blaze
Installed a larger ground cable, moved the battery from the driver to passenger side, and cleaned up my ground connections. This all increased my cranking voltage so i get a nice big spark while starting. Lets hope it starts now.
Old Jul 18, 2013 | 02:53 PM
91blaze's Avatar
91blaze
It runs now. Turns out the timing mark on the balancer had moved so it was timed a bit too far advanced. After messing with it a bit i got it to idle around 800 and has pretty good throttle response. Still needs some tuning though. Next on the list is getting the brakes bled and hooking up the flywheel to the converter so i can see if it drives nice. Also got some new parts like headlight reflectors and a hood prop so i can stop tearing up my paint. Its getting closer and closer to being done.
Old Aug 2, 2013 | 05:58 PM
  #28
91blaze's Avatar
91blaze
Haven't had much time but getting a little more done. Got all the coolant lines hooked up including the trans lines. Just need to make a coolant reservior. Also got the flywheel bolted to the torque converter. Plan on bleeding the brakes once i get some time.
Old Aug 4, 2013 | 03:03 PM
  #29
91blaze's Avatar
91blaze
As my luck would have it, the last bleeder screw broke on me. Now for the fun job of trying to get it out.
Old Aug 4, 2013 | 03:19 PM
  #30
91blaze's Avatar
91blaze
And the screw extractor broke... FML
