2004 Exp 4.6 misfire codes.
Old May 3, 2013 | 11:57 AM
VRC9170's Avatar
VRC9170
In the middle of the Rocky Mountains the “Service engine soon” dash light started to flash and the engine had a miss. We had it scanned about two hours later and it was cylinder number 6 misfire, so put a new spark plug in it. It ran good for a mile then came back on again. Two hours later I bought my own code reader and it read the same code – P0306 – meaning a misfire on the 6th cylinder. I had a new plug in it so decided to swap the coil (one on each plug) for the one in Cylinder five and reread the codes. Sure enough the code read P0305 for the 5th cylinder. I bought a new coil for $70.
We got home yesterday and the car ran perfectly. So today what do I do? I mess with what is working well and replace the other 7 plugs. That means pulling each coil off, replacing the plugs and re-installing the coils. Now I have misfire codes on cylinder 7 and 8. Something to tackle tomorrow I guess. I found the left side has oil on the plugs where the wires connect. I wonder if that can cause the codes? maybe more of the coils are intermittent and failing. Might be an oil leak from the rocker cover gasket. 195,000 KM about 117,000 miles on the truck.
Bob Bates
Old May 3, 2013 | 04:08 PM
aquanaut20's Avatar
aquanaut20
Check all the lances on the COPS, they may be contaminated and arching.... Philip
Old May 4, 2013 | 02:46 PM
VRC9170's Avatar
VRC9170
When I had them off they looked sound. There was oil on the left bank plug holes and the lances were oily. I know oil does not conduct electricity and I am wondering if it can be preventing the spring to plug contact intermittently.
The plugs fire smoothly for awhile,then intermittently misfire.
Could be the lances in question are split. I am going to replace them. They are inexpensive anyway.
Bob Bates
ZEvans
27
Mar 3, 2015 06:57 PM
busflyer
Modular V8 (4.6L, 5.4L)
Nov 19, 2013 04:12 PM
mikejaros
Oct 6, 2011 01:30 AM
broken ford truck
1997 - 2003 F150
Jul 1, 2010 09:19 PM
mahskeeter
1997 - 2003 F150
Mar 30, 2010 11:34 PM
