please help
Old May 3, 2013 | 07:53 AM
powerstroke451's Avatar
powerstroke451
please help
Driving to work out of town and low fuel pressure came on screen.... fuel filters??
Old May 3, 2013 | 09:32 AM
CascadeF250's Avatar
CascadeF250
Fuel filters would be the first thing to change How many miles do you have on them? I would change them regardless of the miles. You could have gotten some bad fuel and clogged them.
Old May 3, 2013 | 09:35 AM
marchare011's Avatar
marchare011
YIKES!!! Did the truck shut itself down? Did it run worse? Could it be the low pressure fuel pump? If you shut it off, does it reset?
Sorry for all the ?'s. Wish I could help. Let us know what happens.
Old May 3, 2013 | 10:09 AM
SavageNFS's Avatar
SavageNFS
I'm with Ron and Cascade...drain the water separator too and see if you have some water in there. Sounds like trouble unfortunately...sorry.
Old May 3, 2013 | 10:52 AM
powerstroke451
Ok for an update I drained the water separator and no water. Went to change the fuel filters out, got the one under the hood just fine. Went to change the one on the rail and broke the housing finally got my new housing $29.95. Got it all put back together and running good.. what a busy morning!
Old May 3, 2013 | 10:57 AM
SavageNFS's Avatar
SavageNFS
Wow...that is GREAT news!
Old May 3, 2013 | 12:06 PM
marchare011
WHEW!!
Just curious, did you shut it off and try a restart prior to changing the filters?
Also, I assume since no water in DFCM, everything else looked okey dokey?
Glad you're up and running. Thanks for the feedback.
Old May 3, 2013 | 12:30 PM
Tom's Avatar
Tom
I think you guys are getting worked up over a common issue that doesn't mean trouble of any sort. There is a pressure switch near the secondary fuel filter that opens below 75 PSI(IIRC) and alerts the driver through a warning indicator. It also reduces power output in order to protect the HPFP from fuel starvation.
This is typically an indicator of plugged fuel filters and nothing more. If your fuel gels in the winter this will be the first symptom. It is NOT a telltale sign of HPFP failure in any way, nor does it have anything to do with water in the fuel system.
Old May 3, 2013 | 01:00 PM
SavageNFS's Avatar
SavageNFS
I might agree with you on an older truck, but given he has a newer truck and I made the decision to give him the benefit of the doubt on fuel filter maintenance from some of his other posts (which was wrong, imagine that). It had potential to be something major and it wasn't. Turned out to be a simple fix and I'm happy for that. I never got worked up and I didn't get the impression Ron did either, but thanks for judging the situation after the fact
Old May 3, 2013 | 01:16 PM
Tom's Avatar
Tom
We still have lots of anxiety of HPFP issues, and my point was that this can't possibly be related. There aren't many things that can cause this, short list includes a bad lift pump, plugged filters, or a defective switch, with plugged filters being far and away the most common.
Exactly which major problem did it have the potential to be? A $250 fuel pump, $50 set of filters, or a $30 sensor?
Old May 3, 2013 | 02:00 PM
SavageNFS's Avatar
SavageNFS
See this is exactly how forum discussion escalate. You're a good guy Tom, but I didn't appreciate you saying Ron and I were getting worked up, that's it. If you want to turn it into something that it wasn't be my guest.
Ron and I have never jumped on any of the HPFP hype or participated in those threads in a negative manner.
Old May 3, 2013 | 02:12 PM
Tom's Avatar
Tom
I apologize, I never meant to offend anyone. It's been a rough week at work and I sometimes don't think before posting.
Old May 3, 2013 | 02:50 PM
marchare011
It's all good.
I didn't think I was worked up either. I was simply trying to show genuine concern for the guy. If you look at his post time versus mine, which when I started posting there was no other replies to his original, there was 1 1/2 hours and no one had replied to his question. I was trying to brainstorm with him. I did throw out the low pressure fuel pump as a possible cause, and asked if it reset upon a re-start. None of what I posted, I don't believe, insinuated a HPFP problem. Oh well, it doesn't matter. The problem is fixed for now, and I for one learned something new.
Savage, thanks for watching my back while I was at Wally World.
Tom, it's Friday buddy. Hopefully the long work week will melt away soon. The problem with texting, posting, e-mailing, etc. is you can't see someones face and body language over the airwaves. I try to be careful what and how I write on these social medias because it is sometimes very impersonal.
Hope all have a good weekend while I go work my four night shifts.
Old May 4, 2013 | 03:41 AM
powerstroke451
I am very good with my maintenance I replaced both fuel filters 7500 miles ago. I am guessing I ran into a bad batch of diesel on my last fill up. I also did not believe it was an hpfp failure but I did want to get some ideas brainstormed since I'm away from home at work. Have a great weekend all! And I'm with you on working nights 12 down 2 more to go then its back home for days off!
Old May 4, 2013 | 06:50 AM
Tom's Avatar
Tom
I agree with your thinking about a bad tank of fuel. I remember a few years ago while working for Roehl everyone was complaining about how fast our fuel filters plugged after filling up at our Chicago terminal. It never caused any harm to the engine(although this was a MEUI injection setup on a DD60), but it would go through filters quickly.
I think this is the reason the pressure switch exists, as you were able to solve the concern without starving the HPFP which could potentially cause serious issues down the road. The system worked as designed.
