newbie help
Old May 3, 2013 | 03:06 PM
tabijan's Avatar
tabijan
Is there spark? Does it crank more easily if you disconnect the TFI?
Sixto
93 E150 Chateau 5.8 185K miles
Old May 3, 2013 | 03:12 PM
parkers5150's Avatar
parkers5150
ill check that now
Old May 3, 2013 | 03:18 PM
parkers5150
i pulled the wire out of the top of the dist. to check for spark w screwdriver... i could not see spark but the engine turned over easier. re attached the wire and the engine had hard time turning over and when finished i heard a wooosh or the sound of releasing pressure???
Old May 3, 2013 | 03:21 PM
fordman75's Avatar
fordman75
Did you pull the distributor out when you changed the module? Or did you just turn it?
Old May 3, 2013 | 03:26 PM
parkers5150
i did have to lift it up and turn to get to module but not completely out
Old May 3, 2013 | 03:36 PM
parkers5150
the suspense is killin me guys
Old May 3, 2013 | 03:43 PM
fordman75's Avatar
fordman75
If your battery is charged, then I would say your timing is probably way off. I would get the engine to TDC on the #1 cylinder. Then check and see if the rotor is at the #1 plug wire terminal on the distributor cap. You might have to pull the distributor to get it timed right.
Old May 3, 2013 | 03:49 PM
parkers5150
i guess im gonna have to sit down and read my book for this one
Old May 3, 2013 | 08:35 PM
parkers5150
thanks for the help fellas!!! had to pay the man and get out of the way. Called a mobile guy so got to watch and assist which helped me learn a little more about my ride which was the goal in the first place
Plowboy34
1983 - 2012 Ranger & B-Series
Oct 11, 2016 10:46 PM
ksubigbuck
May 14, 2008 10:05 PM
Point Blank
Aug 27, 2005 05:27 PM
JSHREBEL
Feb 14, 2005 10:29 PM
ngog_nrythrng
Electrical Systems/Wiring
Dec 13, 2004 08:01 PM
