1997 Superduty
Old May 2, 2013 | 04:34 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I've got 4:63's in mine. 2600 at 70 mph. I can get over 13mpg if I keep it around 60, and no hills. Otherwise it's around 12.5mpg.
Old May 2, 2013 | 10:05 PM
cowmilker08's Avatar
cowmilker08
You could do an auxillary transmission. Look up US Gear.
I've never seen or heard of one being used, but I am dying to try it out myself. 3.55 gears suck for towing.
Old May 2, 2013 | 11:15 PM
7DF250's Avatar
7DF250
I have two of the F-Supers. They are great trucks for what I do but yeah 2000+ RPM above 60 MPH really drinks the fuel. I try hard to stay at 55/1800 and can avg. 14mpg but man it's tough to do.
5.13 is the gasser ratio diesel is 4.63. Is it possible someone swapped in a junkyard rear end?
I plan on swapping to 3.73 that is by far the easiest option and most cost effective I think. I can avg 16 mpg and cruise at 65 with 3.73 and still get reasonable performance when loaded. I spoke to a guy who went 3.55 on his (5 spd) and he said it was too high wished he went 4.10 or 3.73.
Old May 3, 2013 | 11:58 PM
oldbird1965's Avatar
oldbird1965
10 lug wheel, sounds like a complete axle swap?
Old May 4, 2013 | 08:09 AM
GM4WALLS's Avatar
GM4WALLS
Front and rear are ten lug... pretty sure they are ten lug from the factory.
Old May 4, 2013 | 11:59 AM
CampSpringsJohn
Yes they are. They made them that way from sometime around 1990 till 1997. They are basically the same thing as an F450. They called them F-SuperDuty instead of F450's. They are around 14,000 to 16,000 pound rated vehicles. I wonder how much it affects their weight rating by installing a higher gear ratio? More stress for sure will be experienced all along the driveline. That wouldn't make much difference driving around empty, but put a load on it, or hook to something.
JIMBO_FID
Sep 23, 2015 11:21 AM
Herman R
Sep 9, 2007 09:30 PM
51dueller
Feb 26, 2004 11:54 PM
jbooker82
Apr 18, 2003 12:59 PM
jbooker82
Offroad & 4x4
Apr 15, 2003 10:17 AM
