Holley 4bbl leak
Old Apr 30, 2013 | 05:06 PM
davewave649's Avatar
davewave649
Holley 4bbl leak
Ive got a Holley 4bbl 600cfm carb on my 302. It has fuel leaking from the bottom of the shaft coming out of the bottom of the housing for the diaphragm for the vacuum secondaries. Is there a seal that can be easily replaced to fix this? The carb was rebuilt about 2 years ago but the slight leak developed in the past few months.
Thanks
Old Apr 30, 2013 | 11:12 PM
LxMan1's Avatar
LxMan1
There are bushings, but I don't think that's the real issue, there should be no fuel pooling up on the throttle blades to even leak out. I would check the rear float level. It sounds a little high and allowing fuel to boil over into the veturies when hot.
Mill2580
May 29, 2017 04:17 AM
kishkumen
May 25, 2014 06:54 AM
JCastellaw
1966 - 1977 Early Broncos
Jun 18, 2008 11:20 AM
CN Spots
Jun 12, 2008 10:27 AM
Jag Red 54
Oct 23, 2006 12:59 PM
