Adjusting Parking brake pedal
Old 07-26-2002, 09:30 AM
Luis_3's Avatar
Luis_3
Luis_3 is offline
HI everyone
I´m going to adjust my parking brake pedal. I just wanted to know if someone has any recommendation for it?? Problem right now, is the light at instrument cluster isn´t working.
Thanks in advance
Old 07-26-2002, 10:32 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
The parking brake pedal on my 1995 F150 is self adjusting. Perhaps yours is too? What problem do you have that you want to adjust it?
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
Old 07-26-2002, 11:04 AM
Luis_3's Avatar
Luis_3
Luis_3 is offline
it seems to work about 60 degrees and light at instrument cluster doesn´t work.
Old 07-26-2002, 11:38 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
So you can get the parking brake set, but just no indicator light. I am thinking maybe a burnt out bulb. Not sure if that is the same light for problems with regular braking system, but my wife's Aerostar did the same thing and I just ignored not having the light. But again, I am not positive your pedal has no adjustment. Also, I think there should be a switch that the pedal lever bumps to turn on the light and maybe that switch is not aligned right anymore.
Old 07-27-2002, 08:45 PM
Luis_3's Avatar
Luis_3
Luis_3 is offline
Ok, I just repaired problem and want to share for knowdlege of everyone.
There´s a switch on top of brake pedal (is a positive switch). It feels some contour of brakepedal (like a cam principle). Mine was not feeling the pedal, it was sticking, and was the problem of having no light at instrument cluster. I aplyied some WD40 to switch´s bolt top and down and it´s working nice again.
Old 07-27-2002, 09:29 PM
Brian460's Avatar
Brian460
Brian460 is offline
