I have a 1990 Ranger 4.0 2WD
I noticed the driver side wheel is sticking out. Further than the
passenger side. tracking does not match the rear like the passenger side does. I have checked the wheel base on bouth
sides and they are the same
I know the 4x4 front end is wider than the rear, does this also apply to the 2WD
do you have all matching rims? if you have different rims, you could have a different offset on one of them. The I-Beams should not be equal length. if they are the same length, then the previous owner has done suspension work on your truck and replaced the passanger side beam with a drivers side beam.
