351 Swap
Old Jun 5, 2003 | 11:35 PM
Cyrezman's Avatar
Cyrezman
351 Swap
I have a 74 F100 with a 302 that I plan to swap with a 351HO from an 85 truck. Should it fit in place of 302 just fine or is it going to have problems (engine mounts, bellhousing bolts, etc.)
I have a C4 transmission if it matters any.
Chris
Old Jun 6, 2003 | 08:09 AM
loudfords's Avatar
loudfords
351 Swap
Simple swap. Exhaust and accessories are the only major obstacles when doing the swap. And you might need to change oilpans and pickup tubes. Check the 73-79 forum for more information, several of us have done the swap, and we all love it.
Old Jun 6, 2003 | 03:49 PM
goofin's Avatar
goofin
351 Swap
you need the oil pan and pickup tube, distributor,
intake manifold from the 351. the distributor may have to be changed if its a tfi ignition. the 351 is taller and wider so if you staying with stock exhaust you will have to modify the 302 pipe or but a new 351 pipe or go with headers. if the 85 has a serpentine belt set up make sure you get everything for it.they use a reverse rotation waterpump and differ from earliar v-belt setups
Old Jun 6, 2003 | 03:52 PM
goofin's Avatar
goofin
351 Swap
also count the teeth on the flex plate to make sure they are the same. either 157 0r 164 teeth
Old Jun 6, 2003 | 03:57 PM
Kemicalburns's Avatar
Kemicalburns
351 Swap
here check out this site. lots of good info on the swap. Ill be doing this on my bronco this summer.
http://www.fast351.com/tech/351w.htm
camccardell
Engine Swaps
17
Apr 11, 2024 10:49 PM
LuckyR
Apr 12, 2014 05:09 PM
brokebronco
Offroad & 4x4
Jun 4, 2005 02:00 PM
beaver24
1978 - 1996 Big Bronco
Oct 26, 2003 02:32 PM
baileys78
New Member Introductions
May 26, 2003 07:37 AM
