6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
How to replace rt blend door actuator?
Old Apr 26, 2013 | 06:00 PM
Notplayn's Avatar
Notplayn
Hi, I have a 08 f350 6.4 with auto/duel zone hvac. I'm hearing a clicking noise on the right side of dash near glove box. Also Pass side vents blow warmer than the setting. I've had the dash apart when installing my audio system so I'm not afraid of it. Just wondering if anyone has replaced one themselves and what the out come was. According to a tsb I saw it quotes 1.2 hrs so I think I can handle it. What I'm looking for is what you removed to get to the part, etc.
Thanks
Old Apr 26, 2013 | 08:37 PM
UGA33's Avatar
UGA33
Not this site, but this should get you going.
Blend Door Actuators, Pic Heavy - PowerStrokeArmy
Old Apr 27, 2013 | 07:19 AM
Gearitis's Avatar
Gearitis
I had mine replaced about a year ago, it is not an easy job. I watched as they took out the dash to easily get to everything. The Tech said, we could do it without taking out the dash, but you have a greater chance of breaking plastic and scrapping up your arms and also it just give more room to do it just about as fast as not taking out the dash.
Old Apr 27, 2013 | 10:39 AM
tgreening's Avatar
tgreening
Only advice I could give is if you're tearing into it to do one, you might as well bite the bullet and do both. Had my right side done, and in less than a year the left side bought the farm. Back to square one.
Old Apr 27, 2013 | 12:50 PM
Notplayn's Avatar
Notplayn
Thanks uga33, that should be very helpful.
I understand both have a good failure rate but if it ain't broke
rowekmr
Apr 15, 2019 07:46 AM
cokeman
Apr 4, 2005 10:04 AM
