no instrument panel lights
Old Jun 5, 2003 | 08:53 PM
torquemeister's Avatar
torquemeister
I just replaced my AM/FM/Cassette deck in my 86 to an aftermarket AM/FM/CD player. The wiring harness from Best Buy did not have the right harness, so I just clipped all the wires and hooked them up directly to the radio. The radio works perfectly fine, but now my instrument panel lights don't turn on when my headlights are on. The 5A fuse had blown, so I replaced it, but they still don't turn on. Is there any way that this problem is the result of something I did in the radio wiring, or do I just need to pull the dash and replace the bulbs?
The radio's wires that I connected ater testing with a test light were:
LG/Y-constant power from battery
Y/Blk-power when ignition is on
LB/R-ground
The other 4 wires were just for the door speakers
Thanks,
TM
Old Jun 5, 2003 | 10:43 PM
82F100SWB's Avatar
82F100SWB
The light blue with red tracer is your instrument lighting, not the ground. There's your problem.
Evan
Old Jun 6, 2003 | 12:44 AM
Mil1ion's Avatar
Mil1ion
LB/R-ground
You state these are the stereo wires not the behind dash wiring.
Ford uses a Light blue/red striped wire to control the variable dash lighting.
What aftermarket stereo did you buy?
Old Jun 6, 2003 | 06:59 AM
torquemeister
I bought a Jensen CD3010X CD player.
This morning I regrounded the radio's ground wire on metal behind the radio. Now I have the LB/R wire with nothing to attach it to. The new radio doesn't have a wire for illumination, since it's an LCD that's always on if the radio is turned on. The only wire that I did not use from the radio's wiring is the blue wire for the amp (which I don't have). Then I turned on the headlights, and put my test light on the LB/R wire expecting it to light it, but nothing happened. Is it possible that more damage was done to the circuit by having the radio grounded on this wire?
Thanks,
TM
Old Jun 6, 2003 | 02:34 PM
steve83's Avatar
steve83
No, if your dash lights still work, then the LB/R circuit is OK. Maybe that wire is cut somewhere else. If you don't need it and your dash lights work, just stretch the insulation to cover the end of the wire and forget about it.
Old Jun 6, 2003 | 04:40 PM
torquemeister
All of the lights work except for the instrument panel lights. If I want to know how fast I'm going when it's dark out, I have to turn on the dome light to see the speedometer. But I was trying to avoid pulling the dash to replace those bulbs unless I was certain that they were the problem, and not something I caused when I installed the radio.
TM
Old Jun 7, 2003 | 01:35 AM
82F100SWB's Avatar
82F100SWB
Did you replace the panel lighting fuse again?? I'm just re-reading your post and trying to think what it could be, and that sprung into my head, you didn't mention replacing it again, as it would have blown immediatley when you tried to turn the lights on with it still hooked up that way.
Just a thought.
Evan
Old Jun 7, 2003 | 05:28 AM
torquemeister
yes, I put another 5A fuse in, but it still didn't work. I'm at a loss right now, so I guess I'll pull the dash today and replace those bulbs.
TM
Old Jun 7, 2003 | 06:54 AM
bremen242's Avatar
bremen242
maybe your '86 is different, but i know my '84 didn't have a constant power source. I had to run one. of course it had an AM radio and one speaker too though.
Old Jun 7, 2003 | 10:47 PM
torquemeister
well I replaced all of the bulbs, and the 15A fuse for the parking and tail lights. all is working correctly now!
TM
