No spark. Please help.
Old Apr 23, 2013 | 09:47 PM
clunker86's Avatar
clunker86
Sorry for double posting. I have this under 80s trucks. I don't know how to move my forum.
i have an 86 f250 i just bought back with no spark. this truck is not original. used to be a diesel. has a 400 out of 81 f250. had this truck running just fine 4 years ago. sold it to a guy running and bought it back 4 yrs later not running.
checked all the connection to make sure they r clean. had the ignition modular tested and tested good. have 12+ volts from the white and red wire. have a little over 6 volts at the bat side of the coil. i have no spark from the coil. i notice every time i connect and disconnected the bat cable i will get a spark from the coil. i ran a test light from the tack test sight on the coil and tried to start and the light stayed real dim and never flickered.
if there is someone that can keep this simple and explain what i need to do to solve this problem will be very help full.
Old Apr 23, 2013 | 10:37 PM
fmc400's Avatar
fmc400
MSEE
Disconnect the distributor and measure the resistance between the ORANGE and PURPLE wires coming from the distributor. The resistance should be between 400 and 700 ohms. Neither wire should have continuity with the BLACK wire.
Kwyckoff
13
Mar 8, 2020 04:51 PM
clunker86
18
Apr 28, 2013 08:19 PM
tstru
Apr 11, 2007 09:54 AM
mouthyturtle
Electrical Systems/Wiring
Oct 2, 2005 06:18 PM
77sc
Jan 23, 2002 01:16 AM
