1978 - 1996 Big Bronco
Transmission pan
Old Apr 21, 2013 | 11:11 PM
Wesley901's Avatar
Wesley901
Transmission pan
Hello!
Today I dropped the transmission pan, replaces the gasket and filter, but didnt fill the fluid back up yet. But I have a stupid question, the pan had a leak because of a bad gasket, and pretty much leaked all of the fluid, so when i replaced the gasket, there wasnt that much fluid I had to drain, but when i did it, i only dropped the pan, because of this is there lots of fluids left in the tranny? or was just dropping the pan and letting sit for like 30mins good enough?
Old Apr 22, 2013 | 04:01 AM
greystreak92's Avatar
greystreak92
It really depends upon how long the pan has been leaking. There are usually several pints still held in the torque converter if you just drop the pan and drain what is there. However, if it has been leaking long enough while the engine was running, the pump will keep pushing fluid through the transmission until there is none left. the fact that there was still some in the pan is a good sign. If the pan had been empty, chances are more likely that the lack of fluid will have cavitated the pump and/or killed the forward clutches. Just went through this with my father's Grand Marquis. He ran over something that poked a hole in the pan. He drove it dry. Shop replaced the pan, 1-2 shift solenoid and the fluid. He drove it a day before the forward clutches failed.
Old Apr 22, 2013 | 11:52 AM
Wesley901's Avatar
Wesley901
I let it sit for a while, so I hope I'm good. Hopefully our landlord will be happy that its not leaking tranny fluid everywhere anymore (hopefully lol) . But I'm sure he doesnt like the probably 10qt thats stained on the driveway .
Old Apr 22, 2013 | 02:03 PM
Encho's Avatar
Encho
The Southernmost Mod
When you remove the pan there will only be 8qts. in there, but the trans can hold up to 18qts, so there is still a lot of ATF in the transmission, for a proper refilling procedure check the final part of this write-up: https://www.ford-trucks.com/forums/1...l#post13059337
ExcursionV10
20
Dec 14, 2021 09:00 PM
smlford
Sep 11, 2015 08:19 AM
morrponies
Jan 19, 2011 03:23 PM
tndiesel
Nov 18, 2007 01:06 PM
metal_mullisha
Nov 10, 2006 10:44 PM
