I've posted them here before. That transmission is made by ZF, so search for "ZF S5-42" and you should find my post with the ratios for both variations.
The post you are talking about did not come up at all. I want to know too.
Don't mean to hijack a thread, but what's the difference between ZFs for 3.55 rear and 4.10 rear? Is it the speedo gear that's different or is it the gear ratios?
Ok, I'll check my tranny tag for the total ratio line. Which opens another question, is it possible to change gear ratios in a ZF for closer gear ratios, even closer than the "close ratio" version? I think the bull low will be overkill for my truck...
