Modular V10 (6.8l)
Vacuum Line Question
Old Apr 20, 2013 | 02:59 PM
V8Notch's Avatar
V8Notch
2005 F350 V10 4x4
These are on the passenger side fender. Should they be plugged together or to something else?
4x4 vacuum hubs don't work and the HVAC selector is defaulted to defrost. I don't have a diagram so I'm kind guessing.
Thanks,
Old Apr 21, 2013 | 10:38 AM
Wolfboro's Avatar
Wolfboro
I checked my 2003 2x4 and it has got different vacuum line set up . What you have on the 90 degree elbow (on the left side of circled area ) , I have a " rubber cap " on that 90- deg elbow (Since I do not have 4x4, hoses are different ).
Suggestion : 1- hook-up that female on the right side over 90-deg male , see if resolves your problem ,
2- If that fails , cap and seal both , see if improves the problems,
good luck,
Old Apr 22, 2013 | 10:26 AM
Ridenred333's Avatar
Ridenred333
What does the one on the right side go to.
78 & 87 Super Cab
Nov 7, 2013 12:44 PM
wanness
Jun 14, 2013 12:53 AM
FordFanboy
May 17, 2013 03:19 PM
Irelands child
Dec 2, 2010 07:51 PM
taylorjs
Feb 23, 2010 11:17 AM
