efi to carb
Old Apr 20, 2013 | 09:34 AM
abreiholz's Avatar
abreiholz
efi to carb
i have a 1989 f150 4x4. it has a 351w and a c6. i want to convert from efi to carb. i know i need a carb, intake, dizzy, fuel pump. what else will i need to get. is there any wiring issues, etc. i am tired of dealing with the stock efi system. another thing i pulled my motor apart and found 2 burnt pistons. what could cause this. thanks
Old Apr 20, 2013 | 11:31 AM
rla2005's Avatar
rla2005
Some recent threads on the the same subject: Ford Truck Enthusiasts Forums - Search Results
Old Apr 20, 2013 | 08:27 PM
GNR22's Avatar
GNR22
Nobody is going to recommend swapping to a carb. You will spend a ton of money for no performance gain and less reliability. What problem are you having with the EFI that you can't find using an OBD1 scanner?
Old Apr 21, 2013 | 12:25 PM
abreiholz's Avatar
abreiholz
the obd port is dead, no power to it. the truck didnt run very well and im doing a complete rebuild on the motor. i am boring it .030 over, and im not sure if that will work with a stock efi. i do have a running donor truck with a complete efi system that i could use.
o--Spooky--o
Mar 2, 2015 12:25 AM
dethomson
Dec 15, 2009 11:46 AM
rebelpride1653
Apr 26, 2009 04:47 PM
4x41977
Sep 8, 2008 04:43 PM
4x41977
Sep 6, 2008 09:12 PM
