AOD Swap
Old Jun 5, 2003 | 09:52 AM
ExplorerRon's Avatar
ExplorerRon
Question AOD Swap
Has anyone tried putting an AOD (Automatic Over-Drive) in one of these trucks? I’ve seen early Mustangs with them. Will the mount work or do I need a conversion kit? My truck is a 1977 F-100 with a 1992 5.0 H.O. C4 automatic 2 wheel drive.
Thanks.
Ron
Old Jun 5, 2003 | 10:15 AM
theonlybull's Avatar
theonlybull
AOD Swap
it will work, with some minor mods. many have done it, i've done 4 myself. if you search for AOD you should find lots of info
Old Jun 10, 2003 | 04:56 AM
ExplorerRon
AOD Swap
This web site does not seem to support 3 letter searches for some reason.
Old Jun 10, 2003 | 11:17 AM
mcguyver's Avatar
mcguyver
AOD Swap
Not for shure on this but I think all you need to do if you have a c-4 is to fab a new tranny mount and shorten the driveshaft. You may also need to tink around to get the linkage to work right.
-Jim
Old Jun 10, 2003 | 08:35 PM
theonlybull
AOD Swap
the linkage is different, the tranny mount is the same, maybe a different location, the drive shaft will have to be changed(lengthwise) and the kick-down requires a progressive movement, not the traditional kickdown movement
Old Jun 10, 2003 | 08:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
AOD Swap
That throttle volume cable is the most difficult part. It has to be just perfect or your tranny won't shift right.
This site does not support 3 letter searches due to processor overhead. You can find out more about it in the site announcements and/or user feedback forum.
