zf6 swap
Old Apr 19, 2013 | 08:14 PM
75Three90's Avatar
75Three90
zf6 swap
after my auto ****s a brick i planned on swapping to a zf5 but somone mentioned that i could swap in a zf6 with no problems what would than entail?
I know for the zf5 it would be puter, wiring, drive shaft, clutch system and pedels
oh yeah its a 96 f350 quad cab
oh yeah i also heard that the 460 zf5 with bolt to the psd is that true as well?
Old Apr 19, 2013 | 08:21 PM
stainlessstroker95's Avatar
stainlessstroker95
The zf6 is way more trouble than its worth. You will need a zf5 from a diesel.
Old Apr 19, 2013 | 08:29 PM
75Three90's Avatar
75Three90
alright, thanks buddy ive done auto to manual swaps on gassers is it about the same as doing it to as diesel
Old Apr 19, 2013 | 08:30 PM
ReBilld's Avatar
ReBilld
X2^^^^^^ The ZF6 isn't just a bolt in swap. The amount of work to put one in isn't worth the trouble. As I have heard it put before, " The juice isn't worth the squeeze".
Old Apr 19, 2013 | 08:35 PM
stainlessstroker95
Bill is the man for auto to manual swaps. Him and tyler have a good write up.
Old Apr 19, 2013 | 08:37 PM
ReBilld's Avatar
ReBilld
Tyler does all the writing, and I do all the work! LOL!!
Old Apr 19, 2013 | 08:40 PM
75Three90's Avatar
75Three90
so bill what all does it entail?
Old Apr 19, 2013 | 08:44 PM
ReBilld's Avatar
ReBilld
ZF5 or ZF6?
Old Apr 19, 2013 | 08:48 PM
75Three90's Avatar
75Three90
zf5 if the zf6 is as much trouble as you say then screw it
Old Apr 19, 2013 | 09:01 PM
ReBilld's Avatar
ReBilld
The ideal way is to have a complete donor truck, but that's not always possible. Since your truck is 2wd, it will be a little easier. You will need.......
ZF5 trans
cross member
trans wiring harness
floor pan with shifter hole
pedal assembly
clutch master and slave cylinders
solid flywheel and clutch assembly
steering column cover
key release mechanism
drive shaft will have to be lengthened
some wiring mods
manual PCM or have your auto PCM flashed to manual
Old Apr 19, 2013 | 09:09 PM
75Three90's Avatar
75Three90
thank you very much bill im starting to save money to start collwctiong parts to do the swap so i was going to buy a part here and there as far as tyhe clutch system im going to buy everything new except the flywheel and tranny. i was thinking it would be better to change the collum. But pretty much what i thought thank you very much bill
Old Apr 19, 2013 | 09:33 PM
ReBilld's Avatar
ReBilld
No problem bud. Do you have a solid flywheel now? If not, you may want to go ahead and include that in your clutch kit. I recommend Valair.Performance Clutch - Ford PowerStroke
Old Apr 19, 2013 | 09:36 PM
fordman67's Avatar
fordman67
460 bell is different.DIESEL IS REQUIRED and only one that will work.
have fun.what u gonna do with the old e4od when you swap it out?
Old Apr 19, 2013 | 09:42 PM
75Three90's Avatar
75Three90
im probly going to go back with a stock flywheel im only wanting about a 300hp motor im thinking i can hit that with stock sticks, by the time i do this swap the e4odamn will be in need of a rebuild why fix somthing that aint broke? thats why the only thing im about to do is new exaughst some gauges and a turner and thats it for the mods
Old Apr 19, 2013 | 09:47 PM
75Three90's Avatar
75Three90
thanks for the link bill ill be getting the 13" fly wheel and the hd organic clutch kit many thanks. and ill probly sell the e40d and price it as a core for rebuild since i know people want a stronger rebuild but dont want to send in their workings trannys
