General Automotive Discussion
Diesel go kart so far...
Old Apr 18, 2013 | 06:23 PM
parkland's Avatar
parkland
https://picasaweb.google.com/1152005...eat=directlink
I started making this go kart like 4 years ago.
Probably about 30 hours of actual work put into it so far, lol.
Seems like usually a lot of liquor thinking happens instead of actual work.
The tubing is all 1/8" wall.
The engine is a 418 cc 1 cylinder diesel.
The transmission, diffs, t-case I picked up a few days ago for 500$.
The engine will connect to the transmission with belts to a jackshaft, then to the transmission with 60h chain and sprockets.
The gear reduction with the belts is 1.6: 1, meaning that at 3600 RPM, the unit could still reach 100 km/h. (60mph). I will buy the sprocket size for the transmission so that 5th gear at 3600 is about 70 km/h. Thats plenty fast as this is supposed to be just a cruising cart, not for racing or jumping.
As of right now, I plan on using shocks from a small car, and air bag springs, as it will barely fit out of the drinking shack ( i mean garage ) because it's tall.
The 3rd pulley on the engine sub-shaft is for a 104 amp alternator.
Plan is to buy mud tires for it in a month or so. Just street tires on it now. Even mud tires the same size should look awesome.
The frame is pretty strong, despite a major mistake. originally, I was going to make this like an articulating steering loader type steered unit, but I couldn't find the parts I needed at the time, so it turned into a conventional steering system half way through.
Anyways, I didn't think it looked really strong, but we used a giant steel beam under it with a jack, and 5000 lbs in the center only deflected just shy of 1/4" from the ends, so that seems pretty tough to me. Especially considering the frame only weighs a few hundred pounds. Lifting either end is not a big deal by hand, mind you the axles aren't attached yet, haha.
100% finished, I think it will weight about 800-1000 lbs.
Lots of work to do yet, but slowly she's comin.
Old Apr 19, 2013 | 08:16 AM
JWA's Avatar
JWA
Clicking your link takes me to a subscription or download page---am I missing something?
Old Apr 19, 2013 | 10:17 AM
parkland's Avatar
parkland
Hmmm i tried logging out, and it still works ?!I don't know, I never used picasa before, so I probably fouled something up...
Old Apr 19, 2013 | 10:24 PM
parkland's Avatar
parkland
Can anyone else use the link?
Seems to work for me on a few computers ?!
Old Apr 20, 2013 | 06:02 AM
shorebird's Avatar
shorebird
Picasa link worked for me.
Old Apr 20, 2013 | 08:50 AM
AirLiftCompany's Avatar
AirLiftCompany
SPONSOR
A diesel go kart sounds awesome!
Old Apr 20, 2013 | 10:00 AM
parkland's Avatar
parkland
parkland
Mar 4, 2014 03:57 PM
Diesel Submariner
Jul 13, 2012 08:42 AM
1949f6
22
Oct 9, 2007 11:32 AM
vogey
Oct 20, 2005 03:08 PM
BlueOvalDrifter88
May 22, 2004 12:59 PM
