glow plug theory
Old Apr 21, 2013 | 09:20 PM
Haines Hooter's Avatar
Haines Hooter
Oldwoods - I'm ignorant of the whole chip thing. How would I find my chip, and how do you figure whether or not to have one?
Old Apr 21, 2013 | 09:28 PM
fordman67's Avatar
fordman67
I have a core engine I am building for my obs and its apart.I will snap some photos of the head arrangement vs valves & gp.
Old Apr 22, 2013 | 04:11 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel
sorry - that was Glenn/Oldbird with the chip comment. I have no chip on my truck, so wouldn't be able to tell you what it looks like.
Old Apr 22, 2013 | 07:12 PM
444dieselrod's Avatar
444dieselrod
A "chip" plugs into the back of the PCM, you would have to locate the PCM first and verify that there is either a chip in it or the black cover is still in place on the back. I highly doubt a van has a chip.
A "tuner" plugs into the OBDII port and rewrites the PCM, then is removed. the only way to know if it has one is if the PO told you about it.
Diesel Rod
Old Apr 22, 2013 | 09:04 PM
cowmilker08's Avatar
cowmilker08
Diesel Rod
Ford can tell you if it has been tuned... For a fee!
Old Apr 24, 2013 | 07:41 PM
Haines Hooter
No thanks, Ford.
The van came with a little digital readout connected under the dash. It was mounted in the cup holder on in the middle of the dash. It had a ford emblem on it and showed RPM. I heard somewhere that it was a programmed idle control for long-term idling. It had been a fleet vehicle up north on the oil fields. I disconnected it because I wanted to use the cupholder for holding cups.
I've always wondered if that controller altered the PCM.
The PO bought it from the fleet dealer and did nothing with this PCM, though he has a tuner on his own F250.
I'll find and check the PCM for a physical chip.
6point0
Jan 27, 2018 05:30 PM
Jordo88
Oct 23, 2016 11:05 AM
IDI-Charlie
16
Feb 20, 2014 03:09 PM
Stage III
17
Jan 21, 2012 01:34 AM
Farmer Jay
22
Nov 1, 2006 08:49 PM
