Shop tips, tricks, and "stuff"........lol
#46
Don, who is the original manufacturer of this thing? Can't read the door on it in the photos.
Do you have a four-jaw chuck for it? Are the headstock threads a standard for which you can get one? (Of course, ANYTHING is do-able!)
That over-head custom drive sure looks unique. I'd bet someone took a lot of time to think that one through. It's now gear-driven off of that, instead of belt?
Any idea of what the slowest speed it?
Good luck with this beautiful old piece! May you be blessed to personally use it for at least thirty more years!! It landed in the right hands instead of the scrapper's, and should be making "stuff" for the next fifty years, at least!
Pop
Pop
The drive system must of taking hundreds of hours to build, and is a work of art!
We have it totally stripped now and hot tanking all the parts except for the main rails, which won't fit in my hot tank......
I don't have a 4 jaw yet........Hey Charlie!....lol
Don't know what the speed will be yet. It had an old 1400 rpm motor on it, and I replaced it with a 3 hp, 3 phase 1725 rpm motor.
Just wish I wasn't quite so busy with house remodeling right now so I can start putting it back together......
#47
Well....... It's gone from this, to this.........and is in pieces all over my shop. But! We got the hot tank up, filled, and running and will start hot tanking all the parts except for the main ways. that I'll have to strip by hand.
With a little luck, and a bunch of hard work, we just might get it painted and installed in the next month!
#48
#49
Good stuff in here. I have always wanted my welder, air and 110 power on a jib.
As to building one for your ceiling, you can get rollers for uni-strut. Build a small frame (with rollers attached) to hang from the runners. Get one of those crappy (just my opinion) coil hoses, mount it to the frame and mid travel. Mount a small cord reel at one end for the 110 power (take out the lock so it will always retract.
Maybe even bolt on a piece of 1/8" thick steel to the side of the runners, mount a disk brake caliper and an ATV brake cylinder with a lock to keep it where you want.
#51
#52
#54
Some good info on penetrants, you guys might find handy!
Penetrating Oils
Machinist's Workshop magazine recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this.
The magazine reports they tested penetrates for break out torque on rusted nuts. They are below, as forwarded by an ex-student and professional machinist.
They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix......... 53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
Penetrating Oils
#56
#58
#59
My newest toy is a Milwaukie M18 "High Torque 1/2" Drive, 18V Impact wrench...........450 lbs of torque........I figure that along with its shop usage, i can bring it along on camping/fishing/horse trailering trips with a couple batteries, and the right sockets in case of tire changing duties.......
#60
An update on my Milwaukie M18 Impact Wrench.......its a BEAST. I gave it a good test today, i changed out 4 tire/wheel combos on my 73 today......Jacked the truck up,one corner at a time, put a 13/16" impact socket on the wrench, and started off with one of the "compact" Li-Ion batteries.......32 snug lug nuts later, both busted loose and re-tightened, so thats 64 uses ALL on one compact battery. Im impressed
