3.55 dif upgrade?
Old Jun 5, 2003 | 01:46 AM
damonlan's Avatar
damonlan
3.55 dif upgrade?
Any one know how hard it would be to move up to a higher ratio from a 3.55 rear diff in my 2001 2wd 4.2 XL. Can I keep the original case? Needed due to power lost after lift and larger tires. Will I still be able to use after detroit locker?
Not the end of the world if I can't, the trade off will be lesser gas mileage. Just something I thinkin I want to do.
PS I have the 8.8 rg axle I believe.
Old Jun 6, 2003 | 07:42 PM
Jimmy Dean's Avatar
Jimmy Dean
3.55 dif upgrade?
Parts are easy enough to come by, 8.8s are common take out the driveshaft (i.e. u-joint,yoke, pull out of tranny) Take cover off, let drain, pull out C-clips, see if you have enough play to pull the axle out far enough without working on the brakes. It is all right there, no problems with using a Locker, I would suggest a limited slip though for street use unless you are going to push over 500 horsies. LIs rie alot better than the rough clicking from a locker.
Old Jun 6, 2003 | 11:15 PM
clown926's Avatar
clown926
3.55 dif upgrade?
dude how big is your lift?
i wanna put a suspension lift on my 2002 f-150 WITH A
Old Jun 6, 2003 | 11:16 PM
clown926's Avatar
clown926
3.55 dif upgrade?
i wanna put a suspension lift on my 2002 f-150 WITH A 4.2 and i was wondering what kinda lift you have and how much you like it and any recomendations
clown926 thanks
Old Jun 7, 2003 | 02:40 AM
damonlan's Avatar
damonlan
3.55 dif upgrade?
clown926-
I went with the 3.5" fabtech. http://www.fabtechmotorsports.com/ Dont just get the spindle lift, you'll want the extra travel provided by the kit. This allowed me to go with the 285/75 R16 tires. You can put bigger tires on but then you'll have less room for suspension travel and only gain minimal ground clearence. I have plenty of suspension travel. I have heard some other users recommend others but I like Fabtech's because of the forged materisls and have had no problems. The blue color looks sharp with the white truck too.
With the switch from 255 tires you'll move up 5 inches in hieght. I would stay away from the larger lift and tires because the tires seem to get much more expensive after 285 size. I believe the factory recommended up to a 305 size tire but I can't quite remember. The 305/70 R16 is the same height as the 285/75 R16 but about an inch wider. May require minimal trimming of the front valance to prevent rubbing but no big deal, they are just much more expensive. The Cooper tires and most of the others recommend a 7.5 inch minimum tire width but the 7 inch width works fine on mine. My brother in law is running the same size tire on his Chevy with 16X6.5" rims and has put them through a abusive off road test with no problems.
Old Jun 8, 2003 | 11:16 PM
clown926's Avatar
clown926
3.55 dif upgrade?
thanks damon that helped me out alot i appreciate it i will let you know what is going on
clown926
