Spark plug help needed
You know full well what is left behind on the plugs.
There are boot removers usually found at the auto stores.
It has a 90 degree bend on the end with a cut out to get under the boot piece left on.
Or you can carefully use a long screw driver to slice the boot at some point so you can get the plug socket forced down to the body.
Remove the rubber guard from the plug socket so ther eis room for the peice left on the plug.
What you must not do is break the plug in place and have porcelean drop into the cylinder.
You don't tear a motor apart for left behind boots.
After it all done, pay attention more often and use the dielectric grease so there is less likelyhood of the boot burning fast to the plug.
I'm not at all surprised the motor dosn't run very well after all this.
A little more attention to maintaince and changing boots would have prevented this.
It's difficult enough to keep thing right with good parts.
Just an example; I can look all the cylinder missfire counts and detect a problems long before is gets bad enough to set a code.
You would be supprised how often a bad boot will leak and cause missfire you can't even feel.
I just ran a issue with poping in the radio and no missfire that could be felt.
Looked at it and see it was cylinder 1. Replaced the boot, it was not that so went on and replaced the coil. No more pop and no missfire counts on that cylinder. All 8 are now zero for missfire counts.
When your doing your own work you have to do it right because you only have the end result to go by without any means to look deeper with test gear.
Good luck.
i'm thinkin about giving up and letting someone else do it, cause cylinder # 4 has a broken boot and there ain't no way in hell i can get any kind of tool back in there to do anything to it. i tried using the plug remover tool without a boot in it to avail.
You either bought the truck with that condition or someone pulled a stunt on you in the past.
I have actually heard of an instance where the owner did epoxy a plug in place on a 5.4 that had blown the threads out but not here on any boards.
Just sounds like your motor was abused through stupidity and neglect.
Now it's time to pay for that no matter who's at fault.
When short cuts are taken to save money and time, somewhere down the road it will be paid for two or three times over.
Good luck.
