1995 front brake caliper change
Old Apr 16, 2013 | 05:06 PM
drewpyd85's Avatar
drewpyd85
My driver side caliper was locking up when I stepped on the brakes it would pull hard to the left and make the wheel hard to turn when going slow (some times). So I changed the caliper, put new fluid in, bled the lines on both sides of the truck made sure no air was in it. Just test drove it and it drives fine and does not pull anymore but I feel like there's a bit more travel in the pedal now. It stops fine when you slam on them just didn't know if this was normal or its just my head messing with me. Anything I can do to check if everything is good.
Old Apr 16, 2013 | 05:20 PM
maytag906's Avatar
maytag906
Did you adjust the rear brakes?
Old Apr 17, 2013 | 09:25 AM
drewpyd85's Avatar
drewpyd85
no, i was driving it around today and i think it may be in my head. it stops fine. everytime i **** with something my mind plays tricks on me and i think i get paranoid and look for more problems
Old Apr 18, 2013 | 06:05 AM
96f350az's Avatar
96f350az
i could be backwards but i believe you should bleed the brakes from the back pass, back driver, front pass, driver front. did you do this? also you could either adjust the rear brakes with a flat head or the proper tool. or just put your e-brake on and drive forward to loosen, backwards to tighten .. at least this is what ive done in the past.
Old Apr 19, 2013 | 02:52 PM
drewpyd85's Avatar
drewpyd85
i thought the rear brakes and front brakes were separate from each other. and i never heard about that backing up with the ebrake on before
navistarnut
Apr 6, 2017 10:13 AM
Dan Robertson
1997 - 2003 F150
Nov 10, 2014 08:23 PM
Critterhunter
1983 - 2012 Ranger & B-Series
Feb 7, 2005 10:41 AM
jwtaylor
27
Sep 24, 2004 05:09 AM
35l911
Jan 5, 2004 09:44 PM
