OEM vs aftermarket calipers/pads
Wanting to upgrade my brake system in the near future, so I'm just researching different brands and whatnot right now. I'm wanting to do my pads, calipers(maybe) and rotors.
I've heard great things about EBC, mainly the yellowstuff pads. Their drilled and slotted rotors are expensive, like 550 for the rear set and I've read to stay away from drilled rotors. They also don't sell calipers that I know of.
Raybestos seems to have a good rep for their slotted R300 rotors, havn't read much on their calipers.
If possible, I was thinking about doing the EBC yellowstuff pads, the Raybestos r300 slotted rotors and the Raybestos calipers. I wasn't sure if the combination of EBC pads and Raybestos calipers and rotors would work, or if even a good idea.
Also, what is y'alls opinions on OEM calipers and Raybestos or other aftermarket calipers? Which is better? Is the performance from aftermarket calipers worth the little bit of extra money?
The truck is a 2005 F250 4X4, thanks for any input.
what determines braking power is total swept area, and compound
material used, and hydraulic pressure applied.
rotors don't do it.
calipers don't do it.
Look at Brakemotive.com. They are an Ebay seller. I am towing a 18k gross 4012 Cyclone and have never had an issue. I go with the upgraded tow pads and have never had a warped rotor or fade issue. On my last rotor/pad replacement i gave my front old rotors to a friend as they where as new
My truck weights in at 12k every day and it also tows a 10k dump trailer.
I put on ART brake rotors and pads two years ago and could not be happier.
Applied Rotor Technology
Purchased pads and slotted rotors in 2008 from Wheeler's Off-Road and the prices are pretty stable which is amazing... The Carbon Kevlar pads have been great for my 03 which is a big improvement over OEM.
I noticed that also, they are physically bigger than 2003 models. For MY 2003 the prices are still pretty much the same.
