fuel pump?
Old Apr 15, 2013 | 09:20 AM
Ducky F150's Avatar
Ducky F150
fuel pump?
On my way to work this mornin my truck died it isnt gettin fuel ive pushed the fuel reset behind the kick panel there isnt a fuse or relay and i called a dealership about that i dont know i wouldnt think the fuel pump would go out all at once any ideas would be helpful its a 04 fx4 super cab 5.4
Old Apr 15, 2013 | 10:29 AM
jr105's Avatar
jr105
Fuel pump driver module. Located on a cross member above the spare tire. It's a common problem.
Old Apr 15, 2013 | 11:03 AM
Ducky F150's Avatar
Ducky F150
I guess it wont feed power to the pump then
Old Apr 15, 2013 | 11:26 AM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Drop your spare check the Moudule by taking it off the frame if any holes in it that will be the problem about $100 at ford.
Old Apr 15, 2013 | 12:42 PM
Coskid's Avatar
Coskid
Yeah this happens all the time. I think the new modules have a rubber piece that goes on to keep it off the frame and stop it from happening again. It is a super easy fix and anyone can do it in their own driveway.
Old Apr 15, 2013 | 12:59 PM
60DRB's Avatar
60DRB
Old Apr 15, 2013 | 08:08 PM
Ducky F150's Avatar
Ducky F150
How bad are the fuel pumps about going out my truck has 143000 miles on it
Old Apr 16, 2013 | 09:16 AM
Ducky F150's Avatar
Ducky F150
Ok i changed the module and im still gettin nothin it acts like im not gettin power i hit a rough part of the road could i have lost connectipn somewhere
Old Apr 16, 2013 | 11:41 AM
2004 xlt 5.4
Check fuel pump ground wire at tank
Old Apr 16, 2013 | 09:02 PM
Ducky F150's Avatar
Ducky F150
I getting to my witts end ive checked wires replaced the module and i still dont have power any ideas anybody with these fuel pumps just go out
Old Apr 16, 2013 | 09:44 PM
ojai150's Avatar
ojai150
Until you verify that your fuel pump is grounded and getting power, there is nothing else to do..
Old Apr 20, 2013 | 12:38 AM
ifallsguy's Avatar
ifallsguy
ever run the tank dry? Gasoline lubes the pump so if you ever ran it dry, you shortened the life of the pump
Old Apr 27, 2013 | 12:20 PM
Ducky F150's Avatar
Ducky F150
Well i took my truck to the dealership one of the techs said it was my fuse block that was bad thats 500 bucks plus 400 to put it on for a grand total of a grand ive spent on a truck in 2 weeks that i havent made the third payment on yet
Old Apr 27, 2013 | 01:57 PM
ifallsguy's Avatar
ifallsguy
This doesn't sound right. Did they give you the old fuse block back or just tell you it was bad. They sometimes do get corrosion at the contacts (there are contacts where you change the fuse and on the reverse side) but they can be cleaned. Unless this truck had a lot of water in it (flood or leaks) this shouldn't have happened.
You might run a CarFax on it and see if there is any history of flood or accident damage. Not everything shows up, but most things do. Also, did you buy this from the dealer? If so, I would have a talk with the service manager, sales manager or owner, since this isn't normal in these trucks. Ford might be worth talking to. A private owner sales, then small claims court if you find out he hide problems from flood, etc.
And you might check out this site :
Get your CarFax...FREE - Ford F150 Forum - Community of Ford Truck Fans
A member of the F150forum.com has offered to pull free CarFax for forum members. Make sure you read his instructions. You will need to provide the VIN and some addition information. Might be worth checking it out. It does take some time for a response, but it is sent to your personal mail and is free.
Hielerito
Mar 31, 2016 06:24 AM
Critterhunter
1983 - 2012 Ranger & B-Series
Jun 17, 2015 05:11 PM
ron2681
2004 - 2008 F150
Mar 30, 2011 06:37 AM
85F150rd
Modular V8 (4.6L, 5.4L)
Nov 15, 2010 04:01 PM
Rich C.
Aug 11, 2003 11:07 PM
