Used 91 4x4 probs.
Did the 91 XLT LAriat 4x4s come with limited slip front and rear? or as an option? Or did the origianl owner add it.
The truck ws overheating earlier today, It was pissing Anti freeze out the overflow, It felt like it had no flow in the radiator hose going into the engine, and I say no flow goinbg through the radiator with the cap off. It looks like a stuck thermostat..is that a correct assumption?
Is there a problem with the front driveshaft being to short when suspension is fully extended?
Will have more quistions at a later date in time Thankyou.
If you suspect the original owner did some mods, then the only way to know for sure is to open both diffs.
