wont start now
Old Jun 4, 2003 | 08:56 PM
w76ford's Avatar
w76ford
wont start now
i have a 76 f-100 with a 351w with a mallory dist. and ballast resistor. i have started it several times but it wasnt charging so i replace the voltage regulator it still wasnt charging so i bypassed the regulator like it showed it acted like it was going to charge but after it died it wouldnt start again. i have also replace the solenoid, and the module i have 12 volts at the coil but no spark through the coil. i have replaced the coil and checked all the fuses but i cant find any reason it wont start now.
Old Jun 4, 2003 | 09:07 PM
Racerdave's Avatar
Racerdave
wont start now
Sounds to me like its a bad coil,is it a stock replacement? do you have a tach? Maybe the brain?
Old Jun 4, 2003 | 09:12 PM
w76ford's Avatar
w76ford
wont start now
i have used two different coils. one is brand new and i still have nothing. i dont have a tach.
Old Jun 4, 2003 | 09:14 PM
Racerdave's Avatar
Racerdave
wont start now
Computer?
Old Jun 4, 2003 | 09:21 PM
w76ford's Avatar
w76ford
wont start now
i guess i may have to just take it to a shop when i finally get the rear end and drive shaft back on it
