Help
Old Apr 13, 2013 | 05:19 PM
Greg9321's Avatar
Greg9321
Help
Just replaced the battery on my 86 F250 7.5L, about 3 months ago.
Everything was running well until last week, when I would turn the ignition key and there was a slight hesitation, but the engine would turn over.
Went to start it this morning and it was completely dead, nothing was left on, so what do I need to fix?
Thanks
Old Apr 13, 2013 | 05:55 PM
JayzDaddy's Avatar
JayzDaddy
Its possible your alternator went bad and you was running on battery power and drained it. I think these are old enough for that to happen.
Anyway jump it and let it run a minute. Unhook the cables and watch it for 10 or 15 minutes. If it dies your alternator is bad.
If not its the battery. New ones can be bad too. As long as its running take it to advance or autozone and have them test it.
Or if you have a volt meter check the battery cables while its running. Should have about 13.5+ if its charging.
If you cant jump it its possibly the solenoid or maybe the starter up and quit. Or a ground or + cable vibrated loose.
Old Apr 13, 2013 | 09:27 PM
1983F1503004x4's Avatar
1983F1503004x4
Greg:
Please, do not do this. If it's a Chevrolet, you can do this. Doing this to a Ford will ruin the truck.
Optimal voltage on the battery with the motor running is 14.2 volts.
If your truck has "idiot lights", check to see if the battery light is on while the motor is running. If so, it's either a bad alternator or a burnt up voltage regulator.
A Ford alternator has a diode on the inside that can burn up and cause a battery drain with the vehicle shut off.
Check to make sure your battery clamps and cables are rust free and clean first. Unhook them and clean them, then reinstall and tighten them up.
Hesitation on cranking can be a low battery, failings starter, poor connections, etc. So eliminate basic issues first.
https://www.ford-trucks.com/forums/1...e-running.html
Old Apr 13, 2013 | 10:48 PM
Rovernut's Avatar
Rovernut
I think he meant unhook the jumper cables, which is fine, not the battery cables, which should never be done on any running vehicle equipped with an alternator.
Old Apr 13, 2013 | 11:17 PM
JayzDaddy's Avatar
JayzDaddy
Yes i meant the jumpers. Should have clarified.
On the other hand I DID NOT KNOW that removing a battery from a running ford could hurt it. I did do it to my 68 c10 back in the early 90s.
Old Apr 14, 2013 | 07:39 AM
Rovernut's Avatar
Rovernut
An alternator needs a battery to regulate the voltage, it doesn't matter the car make. Without the battery to help regulate the alternator voltage you can burn out diodes in the alternator, not to mention wreck voltage sensitive components. If you possibly have a flakey alternator that you're testing then then you're likely to cause even more damage because the issue could be a bad diode to start with. Rev the engine with them disconnected and you could instantly send 35 volts through the electrical system.
The "remove the cable" test is a holdover from the days when vehicles had generators, and it was ok to run it without a battery. Technology changed and some practices needed to change.
Old Apr 14, 2013 | 08:31 AM
JayzDaddy's Avatar
JayzDaddy
Well when i did it we were starting my truck or a different on then putting the dead battery back in. We were 16/17 or so and never thinking to get jumpers to carry. I only thought they had to do quit because some computers wouldnt run without a battery.
Thank yall for the history lesson.
Korben
Electrical Systems/Wiring
Feb 19, 2017 08:33 AM
Science1974
Oct 17, 2014 08:51 AM
19-F250-78
15
Nov 4, 2012 07:57 AM
thenaes
1997 - 2003 F150
Oct 19, 2011 06:15 PM
Bobtailfan
Nov 13, 2005 09:28 PM
