code420
Old Jun 4, 2003 | 04:56 PM
explorer724's Avatar
explorer724
Question code420
code420- i changed my oxygen sensors all 3of them.also had a tune-up-changed plugs,wires,filters,oil.coil-and just had it inspected and it passed.
Old Jun 5, 2003 | 08:30 AM
thelonerangerxlt's Avatar
thelonerangerxlt
code420
724, my book says code 420 is "Catalyst system efficiency below threshold (bank 1). That sounds to me like a catalytic converter problem on bank 1........???
Old Jun 5, 2003 | 08:46 AM
thelonerangerxlt
code420
724, it seems that a degraded catalyist (code 420) can be caused by a slew of things: lean mixture, rich mixture, running leaded gas, high fuel pressure, wires crossed on O2 sensors, vacuum leak, misfires, just to name a few.......
You probably have a partially melted cat on bank 1. I would pull the codes; this will indicate what caused it.
Old Jun 5, 2003 | 05:11 PM
WillieTD's Avatar
WillieTD
code420
code420? Maybe your X is a pothead.
